Range tanking
Chancellor32
690
460
Queen Creek, AZ
is anyone noticing their range just steadily dropping? LR RWD with 12k miles. Only getting 305 now at 100% not the 325.
Tha_Reaper
89
46
Belgium
there was a batch with a battery problem, that are being called back for repairs. check with your SC if your car matches this. the symptoms are exactly the same as what you are seeing
Reactions: Chancellor32
edigest
154
151
AZ, Sometimes TX
Have you done a calibration charge: < 20% to 100%.
My range dipped fairly significantly at about 5000 miles. I ran it down to 10%, then charged up to 100% and got back to very close to my normal 310 mile range.
Caveat: calibration is not mentioned in the owners manual. However, there are a lot of sources that recommend the "calibration charge" -- and it worked for me. ;)
tesla calibration charge - Google Search
May 12, 2019
18
20
Maryland
I've got LR AWD....about 12k miles, charge to 90% daily, to 100% approx. once a week, and have noticed zero reduction in estimated miles resulting from that charging.
dirtyt3sla suggestion above may be right - 275 @ 90% wouldn't be unusual for me. The slider can also be just a bit off if its been recently moved, and only sitting at 89% instead of 90%. When mine is right on 90% it results in a charge estimated at 278-279 miles. If I leave it sit too long vampire drain can knock it back a mile. But mine usually tops out at 306-308 for 100%, always has.
outdoors
Always roaming
Aug 10, 2014
1,576
2,726
in the moment
Back to 309 now. Got as high as 319 with the software push. Has been a steady backwards decline to where I was prior to the software increase 309. Now just flat. I see some who have it some who don't. With the changes to what I think are the available battery it makes it a little more difficult to calculate the degradation. Mine is also a 2017. That might also play a role? Now just guessing.
Not sure what to think. Happy to have driven 41k :)
Chancellor32
690
460
Queen Creek, AZ
Same love the car! Just wish I knew why my range suddenly fell like 15 miles lol.
