So I have a new 3 and am noticing the battery range declines at a rate faster then the actual mileage I have driven. Anyone else experience this ? For example I will drive a 50 mile route d trip and see battery range decline by closer to 60 miles.
I believe the remaining range shown is the estimate of battery capacity (kWhr) divided by the theoretical EPA usage number (240 Whr/mi) or whatever the actual number is). It does not take any additional factors into account such ambient conditions, your route or your personal driving habits. If you typically use more than 240 Whr/mi your actual range will be less.So is everyone saying that the range isn’t really the range - that it says one range but I can only typically expect to get 20% less? That seems pretty far off. I drove 25 miles and the range dropped 29. About 50 degrees. Mix of highway and local- mostly highway. I guess I am trying to understand implications for longer trip- is 300 miles really only going to be 240 ?
How fast were you driving?I have to say, in my six months of ownership I find the predicted range and actual range to be either EXACT or within less than about 1-2%, with the error usually being in the OVER DELIVER side, rather than getting less range. Now, I was pretty much hooning it in the beginning and THAT does consume a lot of energy. Especially from startup. I did a longer road trip a few months back and managed to go 235 actual miles (at least that is what the trip meter/odometer said and I'm hoping THAT is correct) and the displayed miles used (start miles minus end miles) was only 220. So, I'm happy with that.
Highway, usually between about 74-80, in towns, about 37 in 35, and 30 in 25How fast were you driving?
I drive 74 on highway and will average ~290wh/mi at that speed.Highway, usually between about 74-80, in towns, about 37 in 35, and 30 in 25
Question? When you loose range driving or park, are these lost miles added to your odometer? Ex: They drive 50 miles, range used 60, 60 is added to odometer? New 3 owner myself.Yes this is pretty normal - depending on a number of factors, the car may manage more or fewer miles than the estimated range due to higher power consumption than predicted.
Factors impacting range are:
- Speed (generally faster means more power used)
- Temperature (colder external temperatures means more power consumed)
- Wind or incline
- Internal heating (cabin heating uses the most power, followed by AC followed by seat heating)
- Driving style (heavy feet use more power)
- Highway Vs stop start (highway driving gets very little regeneration)
Additionally your car will use power when standing still, or even while asleep (if not plugged in). Generally, if you can average about 250 WHr/Mi or below, you should hit drive equal to or greater than the distance estimated.
