Ranger service using car lift
Discussion in 'Model S: Interior & Exterior' started by rainman50, Oct 28, 2014.
  1. rainman50
    rainman50 Member
    Midwest
    I don't know if this is the correct place for this post so I thought I'd still give it a shot.
    Tesla says that their rangers can't fix certain problems because they don't have a lift and therefore need to to take it to a service center.
    I'm about 180 miles from a service center so I'd use a ranger to check out problems with the car. If I had a lift , which I intend on getting one soon, would a ranger be able to use it to fix certain problems.
    I guess I can ask a service center but thought I'd ask here to see if anyone had one and it worked out in them using it
  2. ribsandbbqbeef
    North America
    I don't have a lift, nor did I ask a SC; however from a liability stand point and our litigious culture, my guess is the answer is no even if you owned a lift. What happens if your lift fails and crushes the ranger? Does your home / liability insurance cover use of your equipment by a professional? Will Tesla's workman's comp pay for the ranger's injuries since he's on the clock, or will you since it's your equipment that failed?
  3. NEWDL
    NEWDL R#350 R#1323 Sig23(traded) 8136, RWD LR 3, P3D
    NE OHIO
    I do have a lift. The answer is still no. I have asked the question.
  4. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    The equipment they would need, even if you had a lift they trusted and could use, would be back at the shop. Not to mention parts that need repair or replacement. The Ranger vehicles are usually stocked with the tools and parts they need for local service. I'm about 220 miles from my closest service center. It really isn't a big issue, 75% of the time they have my car back to me the next day. 15% back in 48 hours, and only 10% has it been longer. They usually provide me a loaner and only once have I had to use a local rental vehicle. I know it seems like an ordeal, but they make it work quite nicely.
  5. Gizmotoy
    Gizmotoy Active Member
    Bay Area, CA
    It probably comes down to liability. Can they get insured/bonded if they use a customer's lift to perform maintenance under the car? I doubt it.
  6. rainman50
    rainman50 Member
    Midwest
    Thanks for the responses. I thought that might be the case (liability) and (as others brought up) other equipment as well.
    I'm starting to notice a squeak in my air-conditioning compressor fan and was hoping that I would not have to go to a SC. Ranger might not be able to do it at home.
