As others have said, turn off sentry mode. Unfortunately there is now another battery hog that can not be turned off remotely: Smart Summon standby mode. It keeps the computer running just in case you want to summon your car. By default it's on when the car is away from favorite locations. If you haven't turned it off, it will run down the battery until it's under 20%.
That's what service did for me. They had me turn off smart summon. I had the EXACT same issue parked at TPA. You must turn off smart summon, Come to me, feature. It will drain your battery. Turn it on when needed.
Actually you can leave Smart Summon enabled, you just need to turn off the standby mode. You can still use Smart Summon, but you may have to wait for a few seconds for the car to wake up after launching the app.That's what service did for me. They had me turn off smart summon. I had the EXACT same issue parked at TPA. You must turn off smart summon, Come to me, feature. It will drain your battery. Turn it on when needed.
Yea - I always listen for the lock for that very reason. I've actually not completely shut a door before.
The seat sensor is an interesting one too. Do you have any heavy items in a seat? I've loaded the front seat with enough junk that the seatbelt warning comes on. All cars can think someone is sitting in an empty seat if there's enough weight.
When I'm in public I never walk away from the car for good until I hear it honk and see the mirrors fold in.
Regarding the slightly cracked doors....that comes from my passengers. Despite me telling them to slam the doors shut, they try to be super careful and baby the car. It's a novelty item for them so they don't want to play rough
Yes. Click the standby button I circled and then there is an on/off and some optional locations. Personally I view it as a party trick so I picked “off”. Plus, I pre-condition on the way to the car so that wakes it anyway.I believe it is the blue button that needs to slide to the left to be off and no longer blue.
No, it's enough if the Standby button is grey (as opposed to white). I wouldn't disable Summon altogether, since it's sometimes useful to pull the car out of a tight parking spot.I believe it is the blue button that needs to slide to the left to be off and no longer blue.
Great idea! Could also do a Car Wash profile that puts it in neutral, turns off the wipers, and folds the mirrors.Rather than have a mode, such as "Airport mode" the car should have profiles.
You could then have a profile, such as "long term parking" which, obviously could be used at home, an airport or anywhere.
Another profile could be "winter commuting" or "summer road trip"
In each you could set your HVAC temp, and other settings with just one tap or voice command.
In the setup screen you could configure all the vampire electrical drains and HVAC when the car is parked as well as HVAC and maybe other stuff when it is driving
Story end: The leak slowed to a trickle in the mid forties and by the time I got back I had 38 miles left. To rub it in, the warning for reduced range due to low outside temperature immediately came on. However, by limping home, driving 45mph on the freeway, I made it back with 10 miles on dial. Hopefully I didn't hurt the battery by draining it so close to zero. Up to this point I had been babying it by keeping it between 40% and 80%.
As a side note, I don't remember if I had fully charged my 2015 Nissan Leaf before I left, but when I got home, it still had 93% of its tiny battery left.
Sorry if this was mentioned but would Power Off work in this situation? How much does it actually turn off?
Also, I would Uber/Lyft there and leave it at home.
