Rate of charge at using a NEMA 14-50 outlet
volkerbradley
104
20
United States
I've made arrangements to charge my P90D at a campground in the Upper Peninsula of Michigan. They have NEMA 14-50 plug.
If my battery is at 20% when I start charging and I plug in at my Tesla 80 AMP home charger, the display states that the charging rate is about 41 miles/hr.
If the car battery is 20% when I start charging, what would the charging rate be at a 50 AMP connector at a campground?
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,203
8,338
Colorado
I'm assuming the OP is asking about an X, not an S since this was posted in an X forum and they have a Sig X listed in the signature.
From Home charging installation:
Simply plug your Mobile Connector cord with the NEMA 14-50 adapter into the outlet and the other end into your vehicle. This installation will provide a recharge rate of about 29 miles of range per hour of charge for Model S and about 25 miles per hour for Model X.
rypalmer
1,361
1,441
Canada
Slower in Canada unfortunately. In Canada the 14-50 connector is limited to 32 amps continuous, 80% of what it will do in the US.
TexasEV
7,640
8,464
Austin, TX
Also know that battery state of charge doesn't matter with AC charging as it does with a supercharger. The 25 miles/hr for an X or 29 miles/hr for a S is if you're charging from a 14-50 at the full 40A. At many campgrounds the wiring isn't good enough to sustain 40A and you have to set the charging to a lower amperage, maybe 30A. You can calculate the charge rate ahead of time based on the ratio, or it will be displayed on the screen.
Reactions: SW2Fiddler
Evbwcaer
741
328
Minnesota
So how does Tesla comply with this limiting?
If a Canadian Tesla comes to the US, will it pull 40a from a 14-50?
Just wondering how this is implemented: umc, car's home, gps?
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,203
8,338
Colorado
I believe that the resistor in the 14-50 adapter is different.
This thread should have all the details that were discussed last fall: New UMC?
Evbwcaer
741
328
Minnesota
I read through MorrisonHiker's linked thread. If I was in Canada I would buy a US spec 14-50 UMC adapter and use it whenever I can confirm a 50 amp breaker is serving the outlet.
rypalmer
1,361
1,441
Canada
US mandates a 20% reserve from rating to output for safety, hence 50amp rated outputs 40amps. Canada for whatever reason mandates more of a safety buffer. Maybe because they're more polite.
Probably something about most NEMA 14-50 outlets being on 40 amp circuits instead of 50 amps. Just speculating.
ccutrer
1,348
1,228
Eagle Mountain, UT
My X is charging at 40A, 236-240V, 26mph on my 50A breaker, 6-3NM 14-50.
Hmmm.... a 14-50 adapter that automatically limits to 32A? That would be perfect for the 14-50 at my parent's house on a 40A circuit with 8-3NM.
gfb107
209
99
Cary, NC
Brought out Model X 75D home last night, and plugged it into out 14-50 outlet. It was at ~50% charge, both the in-car screen and the iPhone app showed it was charging at 28mi/hr.
TexasEV
7,640
8,464
Austin, TX
That's what is expected, 28-30 mph depending on what voltage the car actually gets (240V isn't always exactly 240V). The SOC does not affect AC charging rate as it does with supercharging-- until the very end at 98% or so.
In car screen and iPhone app will always say the same as they're reporting from the same data source.
