digistyl3
I also had 1067361-77-C installed on my 100D (2017 October), and the rattle is finally gone. Will report back after a few weeks.
I had been tracking this thread for a while, but haven't kept up with the recent posts, so apologies if this has been discussed. I experienced similar rattling starting a few months after taking delivery, and had it addressed during a service visit in Late December. Looks like the same parts that haven't proven to help others, but just adding to the documentation.
Specifics about my case:
Mid-2018 build 75D with air suspension.
Starting hearing rattle at ~5K miles
Had it addressed at 11.5K late December 2018
Currently at 15.5K miles and 2.5 months since, and the rattle has not returned yet nor any other sounds.
Use the suspension level changes multiple times a day (parking at home and work raised to very high, lowered to low on the highway most days)
Below are the note on the invoice.
Customer states the front end rattles when driving slow over bumps.
Technician confirmed customer concern. Removed and replaced front struts
with updated version to address rattle. Vehicle operation tested and verified.
Correction: Exterior NVH General Diagnosis
Correction: Module - Air Suspension - ECU
Parts Replaced or Added
Part Quantity 2
AIR SPRING MODULE FR - MS2 DM SRVC
(1067361-77-C)
Approximately 1.5 months after last change of 77-C record: 77C_SecondAttempt (online-audio-converter.com).wav
Two distinct noises:
1. the rattle from the struts.
2. clicking from the tower braces.
Noise #2 have menifested itself shortly after the #1 originally and never disappeared.
Sounds very familiar!
Just got the 77-C installed for the second time and still hear the #2 noise. But just like after the first replacement the difference in driving comfort is enormous! These "uncontrolled suspension movements" you named before are at least as annoying as the rattle noise to me: It really seems like some "play" inside the struts is developing over time making the car wobble based on road condition.
Test drove with chassis ears, Noise is not in front struts. Move chassis ears to various spots on front suspension, found noise is from LF sway bar end link. Performed replacement of both front sway bar end links and test drove, verified noise is no longer present.
From the first day that I took delivery of my new Model S (March 2018) in San Francisco, the strut rattle was present. By June 2018, the Tesla engineering department designed and installed "temporary fix" replacement struts (which required them to switch my 19" wheels to 21" wheels). The rattle disappeared for two months, but then started coming back. In Sep 2018, Tesla installed the new "permanent fix" 77-C struts and put my 19" wheels back on my car. By Dec 2018, the rattle came back. I am, of course, most intrigued and interested in the sway bar solution that your service center discovered, and I'm wondering if you can please tell me which service center did the work? Many thanks for any info you can send my way!!I have a 2016 Model X with the same clunk/rattle noise at low speeds. It first appeared 18 months ago and they replaced the front air struts. About a month ago it returned. They diagnosed it again as the front air struts using the "chassis ears" and could only replace the left hand one as the other was not in stock. I waited until today to have them replace the right one. When they went to do the work they once again used the "chassis ears" and discovered it was not the strut but the bushing on the left front of the sway bar. The boot had a small hole that allowed water in and it caused corrosion and hence a failure of the fitting. They ended up replacing both sides just in case. I confirmed my rattle/clunk at low speeds is no longer present.
So while I have a Model X those with the same symptoms, especially those who had replacement struts, might want to have the SC do an inspection on the sway bar bushings.
Here is the work they did:
Rocklin, Calif. Ask for Matt.I'm wondering if you can please tell me which service center did the work?
Thank you!Rocklin, Calif. Ask for Matt.
Can you be so nice and report back about your findings? Thank you!Thank you!
We don't know yet. So far only I have reported this fix and on a MX.If the sway-bar bushings are the issue how come new struts (77c) fixes the problem for few thousands of miles?
Maybe the act of lifting the car and moving things around positions them in such a way that they don't rattle until they move back to their normal resting position.
