Rattle noise coming from front Air Suspension (2017-18)
Discussion in 'Model S' started by ptekngo, Feb 7, 2018.
Tags:
  1. bwherry
    bwherry Member
    Los Angeles, CA
    Glad to hear @Happy Kappy - check back in with us after a few months to see if the noise stays gone...
  2. Happy Kappy
    Happy Kappy 2017 Model S P100D and 2017 Model S 90D
    Milwaukee, WI
    I just sold the car.
  3. InternetDude
    InternetDude Member
    Yes
    Is there an updated part # from the 77-C yet? Tesla won't replace the front air struts (again) because there is no updated part. And I don't even have 20,000 km on the car yet. It's just annoying that I have to live with the rattling over bumps. For the $ I paid for the my P100D, they should just keep putting in new ones when they start rattling again. It's sh*t like that why I won't buy another Tesla.
  4. Zuikkis
    Zuikkis Member
    Finland
    "Rattling" sounds more like the stabilizer bar links, not the air struts.
    They cost under 100 and are very easy to replace.
    It's a common issue in any car, not just Tesla.
    • Disagree x 2
  5. bwherry
    bwherry Member
    Los Angeles, CA
    "Rattle" probably isn't the absolute best description of the noise, but there are plenty of other descriptions in the previous sixty pages of this thread: "bobbling", "knocking", etc. Unfortunately definitely not as simple as swaybar links, @Zuikkis. :(
  6. InternetDude
    InternetDude Member
    Yes
    They already replaced a variety of parts including the end links. It’s definitely the struts again.
  7. Raechris
    Raechris Member
    Boston
    Oh yes the low speed chuckle. I had it with my 12-17 MS75D and thankfully the first revised strut 95% fixed it two years ago but it sure was annoying.
  8. Zuikkis
    Zuikkis Member
    Finland
    Ah sorry, should have been more clear the last time.
    I have read earlier posts on this thread. It's noticeable that there are reports from earlier year cars (2012-2016) and even some with coil suspension saying "I have the exact same problem", while it obviously it can't be the same thing as the 2017+ air suspension rattle.
    The point I was trying to make, if you have mysterious rattle, changing the swaybar links should always be the first thing to do because they are cheap and very easy to change even by yourself. There's someone on page #1 on this thread saying he changes the links annually because they always start to rattle again.
    About the air strut problem.. I actually was official importer of K-Sport suspension products in Finland for several years. One customer had very similar issue in his aftermarket K-Sport air suspension. It made weird sounds and also the height adjustment seemed to go in "steps" and not smoothly. The issue was that when the strut is moving up and down, air can get trapped in small "pockets" between the airbag and the damper. Then when there's enough pressure difference, air leaks out and makes a sound. The manufacturer provided instructions how to fix this by removing a rubber "sleeve" inside the bag:
    While this does not directly apply to Tesla, it's probably something similar. I undesrtand that if car is under warranty it should be fixed by Tesla, but still it might be beneficial to visit some shop that does aftermarket air suspension installs.. They are probably familiar with these kind of problems.
    • Informative x 3
  9. bwherry
    bwherry Member
    Los Angeles, CA
    Thanks for the info @Zuikkis. My car is still under warranty, so I don't want to start fiddling with things myself - would rather have Tesla sort it out like you said. Good to know about that K-Sport rubber sleeve removal solution though... If I still have this problem after my warranty maybe I'll see if that's applicable here! :thumbup:
    Brian
