Rattle sound and steering shakes when changing lanes or driving on pavement reflector markers.
Discussion in 'Model S' started by bakchod87, Apr 11, 2017.
Tags:
  1. bakchod87
    bakchod87 Member
    Chicago
    So I have had my MS for almost two months now. 90D with HW2 and all glass roof. I started noticing a weird rattle noise coming from the left side of the car around the front left tire when changing lanes. Or anytime I drive over a broken or cracked area on the road concrete or over the pavement marker reflectors, the car makes for few seconds (while driving over these depressions or cracks in the concrete or pavement markers) a weird rattle sound and also the steering shakes a little bit for the duration of the sound. As soon as I switch lanes and pass over that cracked concrete on the road, the sounds goes away. However, I didn't have this issue while driving over the same roads for almost 7 weeks.
    Anyone else experienced/experiencing the same issue? I am worried it may be a larger underlying problem.
  2. BlueRocket
    BlueRocket S90D HW2 MCU1
    New Jersey
    It is likely the center line departure warning. Try turning that off and see if you still have the problem.
  3. bcampbelllds
    bcampbelllds Member
    North Dallas, Texas
    Your lane departure warning is on. You can disable it under controls.
  4. NikeWings
    NikeWings Active Member
    Los Angeles
    Yep ^^^^ what they say. Sometimes various settings become reset during software releases and you've got to go back and customize them again. Unpredictable as to which, if any, settings until you stumble upon them. PIA but harmless.
  5. Dreamship
    Dreamship Member
    Dallas, TX
    Or you might try using your blinker when you change lanes--you know, as a courtesy to other drivers.
