Rattles ?
Discussion in 'Model X: Interior & Exterior' started by electricity, Apr 11, 2016.
  1. electricity
    electricity Member
    Florida
    i took a test drive of a model x. Love the car but there where a couple things that kinda dissapointed me. The car had a rattle in the dash.. and windnoise was kinda loud i guess from the front rear view mirror on the drivers side ? I was kinda dissapointed with the rattle to be honest.. On a new car? How are the service centers in silencing rattles ? If that car allready had a rattle how is it going to be 2-3years from now . Any thoughts ? Thanks!
  2. siucity
    siucity Button Pusher
    SF North Bay, CA
    I had a rattle in my dash when going over rough roads (which isn't uncommon around here), and the service center took care of it. It's a tough job pinpointing the source of the rattle, but they were able to do it.
  3. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    The wind noise may be the window gasket. Some are not fit correctly. Mine had gone over the window instead of under. I just poked it back in and let it sit for a week. This solved my "problem" and my wind noise is minimal if at all. Bigger noise seems to come from tire noise in my car and I am AS 20" Conti's.
  4. roser
    roser Member
    Burlingame, CA
    I have rattles all over. They seem to multiply and get louder daily. It's been to the SC once and it wasn't fixed. Going back in tomorrow.
  5. Mark Z
    Mark Z Active Member
    North Orange County
    A new rattle started after the passenger door latch was replaced. Very annoying and my passengers agree. It is most present at speeds about 15 to 25 mph on roads that provide a slight rocking action.
    Some of the plastic parts can creak, but those are not as frequent. At highway speeds, the wind and road noise help mask the rattles.
  6. roser
    roser Member
    Burlingame, CA
    After 2 visits and about 25 days in the SC, my many rattles seem to be gone. Some of the culprits were loose trim, cables/wires not secured within the doors, loose screws in the visor. As with Mark Z, I still have the creaking, and the rattles (when they were present) were mostly noticeable at lower speeds on rough roads.
  7. Desmo999
    Desmo999 Member
    Redwood City, CA
    The right side of my dash started creaking incessantly after about 500 miles. Smooth roads, rough roads - didn't matter.
    Since SC's are backed up over a month, I decided to try and pinpoint it myself since they can't look at the car until June. Pressing on the dash didn't seem to help isolate it, but after removing the pop-out side panel on the right dash, it was super easy to duplicate. Tesla basically has a single rub strip between the upper and side pillar "grills" and the grills rub ever so slightly against each other and make a creaking noise. The left side fit is really tight, so the single rib strip might be helping more, but the right side one has a bit of a gap, so there's no real dampening coming from the thin factory rub strip.
    Fix:
    1) Pop off right side panel*
    2) Confirm creak
    3) Cut some small strips of adhesive weatherstrip foam
    4) "Tuck" adhesive foam into the gap so it sticks to the lower grill "tab"
    5) Pop side panel back into place
    * Removing the side panel allows some "play" in the dash so you can tuck under the grill tabs. It also allows you to confirm the creaking sound and that you've fixed it when you press a bit on the dash with the panel out.
    This fixed my dash noise, but a better fix may be to run a strip across the entire grill gap to prevent other contact points. It just didn't look easy to get in between the two parts without removing the top of the dash, and this will be more involved than simply popping off the side panel. I'll ask the SC about it next month when the car goes in for other fixes.
    Creaking sound from grill contact
    Pop-off side panel
    Cut foam weatherstrip
    Tuck foam pice in with tweezers or a small screwdriver to reach under grill "overlap"
    • Informative x 3
  8. aesculus
    Northern California
    Any tips on how to safely remove the grill panel? That looks dangerous.:eek:
    If it is really just the two grills rubbing each other wouldn't it just be easier to shove the foam or some cardboard between the parts in situ?
    Note: Autocorrect wanted to change grills to girls above. I was not going there. Could have started a whole flame war.:)
  9. lloyds
    lloyds Active Member
    Bay Area
    I had a rattle on the seatback and it was addressed on my last SC visit.
  10. Desmo999
    Desmo999 Member
    Redwood City, CA
    The side panel is easy to pop off (standard automotive style body clips). Just get one edge up slightly and work around the edge popping one clip at a time with your fingers.
    The top of the dash and speaker grills are another story... They're pretty secure and I wasn't going to risk pulling too much. I just needed the play with the side panel removed to confirm the squeak. It was easier to pinpoint with some movement.
    The a-pillar cover probably lifts out, but I'm guessing you need to start popping clips by the door roofline and work down to the dash using a trim removal tool.
  11. aesculus
    Northern California
    Today three of road in the car. The car seems to have developed a weird squeak on the passenger side of the car. We held onto the front seat passenger back and it went away and tried it again without holding it and it squeaked again. So something causes a squeak in the front passenger seat back.
  12. CaliX
    CaliX Member
    Los Angeles
    Call your SC they will fix it. I had the same type of squeak in my dash they found a clip not properly seated. They also fixed several rattles I had.
  13. aesculus
    Northern California
    Since the car was new I have had a rattle in the passenger FWD. Had to take the car to service today to get the fobs swapped and they also put in a new set of front door latches. While I was there they took a look at the rattle we have and this is what they did:
  14. Ormond
    Ormond Member
    Central Florida
    My front passenger seat belt latch rattles against the hard plastic seat back. I buckled it to make it stop. Any better suggestions?
  15. Heater71
    Heater71 Member
    Indianapolis
    Not elegant, but I just moved seat forward.
  16. Helvetio
    Helvetio Member
    Sunrise, Florida
    I have the same issue. I found that if the passenger seat is moved far enough back the buckle will hit the leather of the seat and not make much of a noise.
    If only we could move the passenger seat from the main display......
