  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Raven long range real world 0-60
Krash
Data Technician
Moderator
Apr 18, 2017
2,627
2,984
Intermountain US
w rollout but below full charge...
Krash
Data Technician
Moderator
Apr 18, 2017
2,627
2,984
Intermountain US
Don't get too excited. Consider the rollout is at least a half second the way those two runs catch the quarter second (API recording) snapshot. Also I am not sure the raven S has the same high speed passing power as the pre raven S. I still need a quarter mile run to compare. The RWD 3 definitely has a drop in the power curve when back EMF for that smaller, more efficient PMSR motor spools up. And that rear 3 motor is similar to the raven S front motor.
I'm sitting here with a 2014 P85D that got 253-miles of range (when new) and did 0-60 in the low 3 second range looking at about the same 0-60 with 370-miles range in a car that has received incremental updates over the years with my mouth agape. That's pretty damn impressive no matter how you slice it. I, too, would like to see a legitimate 1/4-mile slip as my guess is it drops off slightly but still.... wow.
Side note: that car also cost $153k in 2014 dollars versus ~50% less now in 2019 dollars. Impressive.
DavidO
74
18
My suspicion is that my car is faster after the new 2020.20.5 update. Took it for a quick spin yesterday on <30% SOC (yes that low) and the pull at low speeds felt sharper. Just subjective at this point as I have no roads around here to fully put it to the test. Would be interested to hear other Raven LR opinions and even better, actual data.
