Another Affordable Carbon Ceramic Brake Option.
Kit Includes:
Front View:
Kit Includes:
Kit Includes:
- 2 ea CCM rotors (Discs made by Brembo; RB discs option available)
- 1 set brake pads (Optional)
- 4 ea Stainless steel new pad bolts (2 ea per caliper)
- Instruction
- Stay in OE configuration
- Save unsprung weight
- Improve mileage
- Re-use OE calipers (save money & trouble)
- Highly affordable
- Direct bolt-on installation - No caliper adapters needed
- Professionally engineered for a bolt on installation
- Easy to find & low cost replacement disc.
- Replacing OE caliper pad bolt with RB new stainless steel bolts to accommodate the thicker CCM rotor (36mm vs. OE 32mm) - This procedure will also correct the OE caliper pad bolt centering deficiency.
- Depending the mfg date, for early models (with black dust shield) modification of dust shield may be required (Instruction will be provided)
Front View:
Kit Includes:
- 2 ea CCM rotors (Discs made by Brembo)
- 1 set CCB brake pads
- 4 ea Stainless steel pad bolts (Replacing original bolts)
- Instruction for replacing deficient OE caliper pad bolts
- Professionally engineered and built by RB for a bolt on installation
- Direct bolt-on installation, no caliper adapters needed
- Re-use OE calipers (save money & trouble in bleeding the system)
- Save substantial unsprung weight
- Improve mileage
- Highly affordable
- Easy to find & low cost replacement discs when needed
