Throwing together a bit of info on the RB rotors for the P3- standard sized kit, looking to do this for removing as much unsprung rotational mass as possible ...
OEM front rotor hat is +/- 7.5mm thick
RB rotor hat is +/- 6.9mm thick
(didn't measure OEM rotor thickness, had wear on it so it wouldn't be a good reading)
RB rotor plate was 26mm thick
OEM front rotor came in at 21.2 pounds
RB front rotor came in at 14.8 pounds
Total weight reduction on the front 12.8 pounds
Only issue with install was the right side rotor was coming in contact with the dust guard under cornering, sanded it down a bit to resolve.
Will add rear rotor info later once those are on. Had technical difficulties with it last night; couldn't get the piston compressed enough (RB's are thicker), and apparently you need to externally power up the motor to retract it further.
