To me, it looks like the mesh portion is the bottom of a sliding door with the black part being the opening for some Knight Rider weapon.
Seems like there's been a pretty big influx of brand new folks here purely to complain about the X. I don't particularly mind the criticisms, but it seems a bit unhinged to me for someone that wasn't a Tesla person to begin with to go to the trouble to go find a forum and do the registration just so they can complain.Might just be a troll. Let us know (via PM) if action should be taken. Seems harmless so far.
Ok, so it's late and I've been drinking so please forgive me but I recall from some early Model S pics/discussion that they showed the front end with large "radiators" on each side and they were saying that one was for the cabin and the other was for the motor, PEM, battery cooling.Roadster doesn't. In any case, I was referring to a radiator in the classic ICE where you need air flowing over a water filled container. The liquid cooling in the Model S (and I guess the X) runs through the AC and is not water cooled AFAIK.
Model S Alpha 'radiators' pic:
http://gigaom2.files.wordpress.com/2011/03/teslaalphatourfrontend2.jpg
Guys, this stuff is discussed in other threads. You may not want to call that thing under the hood of the Roadster (with the big fans on it) a radiator, but it certainly is a heat exchanger. And the Model S has at least three heat exchangers in the front. One of which is a radiator for the water cooling loop of the motor and inverter (kept around 60C).
I think they kept some sort of conventional-ish looking fronts of the S and X because we're used to seeing that on cars. If they pushed the envelope too hard, it might come across as weird. The 2020 S probably won't have anything other than the barest suggestion of a grille. Just enough to suggest the "Tesla design language" or whatever car designers call it.
I think they kept some sort of conventional-ish looking fronts of the S and X because we're used to seeing that on cars....
I think they kept some sort of conventional-ish looking fronts of the S and X because we're used to seeing that on cars. If they pushed the envelope too hard, it might come across as weird...
