ArtInCT
Always Learning
I find the module temperature readings very interesting. In looking at a few readouts or captures which others here have displayed, each of the 16 modules have differing temperatures. The variances are not drastic however in a few cases 12 of the 16 modules appear to be cooling down as the input fluid temp is cooler than the output temperature. What is puzzling is that on almost each display instance, there are some modules where the output temperatures are lower than the input.
So, this makes me wonder...
Are all of the modules in use EQUALLY at the same time or is power drawn from modules in a round robin manner?
Also, does each module have access to either a cooling flow or heating flow of fluid? By this I mean, can module one be treated to warm fluid to warm it up while module 10 has cooling fluid to reduce its temperature?
