You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
This morning I experienced a sudden drop from 637 kwh/mile to 167 kwh/mile while driving for 10 minutes at this point in 36F temp with a battery pretty much cold soaked since I only pre-heated for maybe 10 minutes before starting out.
I have never seen this happen before and there was no indication of an issue.
I should add that I started out with the battery charge @ 29% so the charge at the point where the kwh/mile just drastically changed was at 23%. I rarely run it that low and I typically keep the pack between 25%-85% SoC.
Has anyone else seen this or heard of this occurring? Is this a sign of an issue with the pack?
