Real Usable Battery Capacity
Capacek
29
0
Prague
Hi Guys,
i am sorry if it is clear for everyone, but can you tell me the real usable battery capacity for P85 Model S?
I can see in several videos and pictures maximal 68 kWh on a single charge - can you post pictures with more kWh used?
On my Model S i made max. 54 kWh with rest only 25km available, but it was not only one trip but whole one week.
Kalud
1,056
285
Montreal, QC
Muzzman1
559
783
Los Angeles
Nice diagram. Where did you find it? I wonder if the EPA range figure of 265 miles (85 kWh) was achieved using the "Zero Mile" Protection reserve. My guess is that the rated 265 miles involves using the battery from full charge to shutdown aka. "turtle".
I'm just guessing here:
Based on 280Wh/mi (EPA Rated rate of discharge) with 75.9Kwh Range charge you'd get 271 miles, so it doesn't look like the EPA estimate dips into the "0" Range.
My 1st range charge at about 1200 mile 2 week old car:
Vger
1,781
209
Salt Spring Island, BC, Canada
I'm puzzled. Why would the display show 271 rated miles if six of those miles are "below zero"? Isn't the "zero mile reserve" supposed to be hidden from the driver so that he/she won't plan to use those miles of charge?
Most Model S's have shown a slight excess over the rated 265 miles RR when brand new. That excess tends to go away within a few months. The very first part of the cell aging (first 10 cycles or so) is more rapid than what happens during most of the life of the battery.
Muzzman1
559
783
Los Angeles
@abasile: My Car's rated range is 271 because it is brand new. As I described in the post above. With a new battery that has 75.9Kw available charge, a perfect scenario, with EPA rated consumption of 280Wh/mi [75.9/.280=271] you get 271 miles on a range charge. After the slow degradation of the battery over time, or firmware changes in recalculations, that number will decrease from 271.
EDIT! I changed my values above as I typo'd my math. It is 75.9 usable KW
Kalud
1,056
285
Montreal, QC
I get a bit too much credit, I actually got the pic from here:
Tesla Model S Buyers', Delivery and Owners' Guide
I think that every new owner come to the same steps. After 5 months and 10,000 km I can tell you that what's really matters is knowing how far you can really drive given the conditions and plan to keep a buffer. After 25 km or so your average will get obvious and you can then compare your real distance to destination (GPS) to the projected range on the energy graph (set on average, not instant). This way you can gauge your buffer all the way and adjust your energy consumption accordingly (speed mostly then heat).
Then after a couple long trip in different condition, it gets quite a second nature and you won't think too much about it... Just need to plan where you'll charge and try to always have a plan b ;)
Capacek
29
0
Prague
Thanks again for the very interesting source page.....btw. i can see that we have same configuration of our Model S (only rear seats is missing in mine)
mgboyes
812
26
United Kingdom
The EPA rated ranges for cars are calculated by taking the results of various different test runs and using some algorithm/formula to combine them together. But I'm fairly sure their individual test drives keep going until the car actually stops, not until its gauge reads empty. Otherwise car makers would be incentivised to leave the smallest possible reserve in order to make their range figures look better. I assume they would have done the same with the Model S.
David99
4,850
7,021
Brea, Orange County
For the most part battery capacity is measured in Ampere-hours (Ah) which makes it easier as the voltage changes under load. Of course voltage also matters as well. It matters in a way that at lower load you can get more Wh out than under high load yet at the end in both cases the battery has the exact same state of charge! I know it makes no sense at first.
The voltage is higher at a lower discharge rate and lower and a higher discharge rate. A 200 Ah battery can be discharged for 2 hours at 100 Ampere or 20 hours at 10 Ampere. At the end the battery is empty in both cases, but the voltage has been higher as it was discharged at a lower rate. As a result you get more Watt-hours.
So far the max I was able to get out of the 85 battery going 2 miles passed 0 miles was 76.5 kWh.
- - - Updated - - -
5 weeks
6k miles
using Superchargers mostly
still getting 271 rates miles
ljwobker
Geek.
Nov 30, 2012
241
22
Raleigh, NC
What is the consensus (if any) on using the capacity that lives between the 75.9 and 81.1 kWh thresholds? I'm looking primarily for how much of this is:
"We don't want customers running out of juice and calling us dirty names"
compared to
"Driving the battery to this level of charge has significant impact on longevity, etc"
ElSupreme
Model S 03182
Jan 13, 2012
4,303
89
Atlanta, GA
This isn't an official Tesla graphic. So the numbers are guessed at. So they are not very precise.
And beyond that going beyond zero isn't reliable. You could go 1-2 miles or go 10. But every foot past zero is a blessing that shouldn't be counted on. If you think you have the buffer you will end up like this:
Ran out of juice, 12V and main pack drained, need info.
SarahsDad
466
3,221
NC
While it's not an official graphic (it appears it was constructed by NickJHowe based on data from Rod and Barbara) and "represent(s) a limited set of data collected over a week or two in one vehicle" according to the original poster, it fairly accurately predicted a finding I noted yesterday - that after a max charge driving down to 1mi remaining, I used 73.4kWh and 251.5 miles. Rated miles were 262 (max charge was 263, w 1mi remaining), with overall 292Wh/mi. This is pretty close to the 75.9kWh from the graphic, and may represent some range loss after 10,000 miles on my car.
russman
394
48
Is there a chart that shows the battery level at each charge level on the car battery marks?
Full charge is 100% = 70kwh
The first notch is 90% so that = x amount of charge
etc...
Yodda
New Member
May 19, 2014
2
0
South Carolina
Hi Kalud,
Do you have this data for 60 kWh model S? I was told by Tesla that you would normally have 56 kWh to use out of 60. I saw on the fueleconomy.gov website the car gets 350 watt-hours/mile fuel economy (35 kWh to go 100 miles). SO if this is the case then the best the Model S can do on range is 56/.35 or 160 miles. this is no the 208 miles offered as the range. My friend has only been able to get 160 miles max on the highway. Anyone else here able to get 208 or higher and if so under what conditions.
