Andyw2100
The 85D did better this time.
I'm going to go out on a limb and guess that it was because you used range mode this time. Looking forward to the write up!
SLC* | SLC* | SLC* | RR** | RR** | TP*** | TP*** | ||||
Location | Time | °F | Odometer | Miles | kWh | Wh/mile | Range Mode | No Range Mode | Battery % | Estimate % |
Leaving breser's house | 7:15 | 55 | 27,889 | 35.6 | 12.1 | 340 | 192 | 190 | 76 | 39 |
Arriving Ellensburg, WA | 8:23 | 59 | 27,966 | 112.7 | 37.2 | 330 | 103 | 101 | 41 | N/A |
Leaving Ellensburg, WA | 9:17 | 67 | 27,966 | 0 | 0 | 0 | 230 | 229 | 92 | 11 |
Arriving Pendleton, OR | 74 | 28,141 | 175.2 | 52.8 | 301 | 44 | 43 | 17 | N/A | |
Leaving Pendleton, OR | 13:15 | 74 | 28,141 | 0 | 0 | 0 | 243 | 240 | 96 | 21 |
Arriving Ellensburg, WA | 15:49 | 78 | 28,316 | 174.1 | 56.0 | 322 | 44 | 43 | 17 | N/A |
Leaving Ellensburg, WA | 16:28 | 82 | 28,316 | 0 | 0 | 0 | 173 | 171 | 69 | 25 |
Arriving breser's house | 17:33 | 74 | 28,392 | 76.9 | 24.9 | 324 | 85 | 83 | 33 | N/A |
Leaving breser's house | 7:12 | 85/53**** | 111,365 | 0 | 0 | 0 | 243 | 240 | 90 | 56 |
Arriving Ellensburg, WA | 8:23 | 58 | 11,443 | 77.4 | 26.2 | 339 | 147 | 145 | 54 | N/A |
Leaving Ellensburg, WA | 9:15 | 68 | 11,443 | 0 | 0 | 0 | 243 | 240 | 90 | 11, 12, 13† |
Arriving Pendleton, OR | 11:56 | 73 | 11,619 | 175.8 | 54.2 | 308 | 45 | 43 | 16 | N/A |
Leaving Pendleton, OR | 13:13 | 76 | 11,619 | 0 | 0 | 0 | 253 | 250 | 94 | 20 |
Arriving Ellensburg, WA | 15:49 | 79 | 11,793 | 174.7 | 54.0 | 309 | 55 | 53 | 20 | N/A |
Leaving Ellensburg, WA | 16:25 | 82 | 11,793 | 0 | 0 | 0 | 205 | 203 | 76 | 46 |
Arriving breser's house | 17:33 | 75 | 11,871 | 77.2 | 23.9 | 310 | 118 | 117 | 43 | N/A |
Leg | S85 Miles | 85D Miles | S85 kWh | 85D kWh | S85 Wh/mile | 85D Wh/mile |
breser's home -> Ellensburg, WA | 77.1‡ | 77.4 | 25.1‡ | 26.2 | 324‡ | 339 |
Ellensburg, WA -> Pendleton, OR | 175.2 | 175.8 | 52.8 | 54.2 | 301 | 308 |
Pendleton, OR -> Ellensburg, WA | 174.1 | 174.7 | 56.0 | 54.0 | 322 | 309 |
Ellensburg, WA -> breser's home | 76.9 | 77.2 | 24.9 | 23.9 | 324 | 310 |
Overall | 503.3 | 505.1 | 158.8 | 158.3 | 316 | 313 |
It's interesting to note that the 85D always ended up traveling more distance. Not a lot but it still did.
You don't really mean that it traveled more distance, right, but rather that it reported a greater distance traveled for what was almost certainly essentially the same distance traveled.
It would be very interesting, for the purposes of the discussion going on in the thread above, to see what something like Mapquest or Google Maps gives as the actual distance for the legs in question, so that we could see how close the S85's odometer is to reality.
From my home to Ellensburg supercharger Google Maps lists 76.4 miles.
Between Ellensburg and Pendleton superchargers Google Maps lists 175.0 miles (both directions are the same mileage).
From the Ellensburg supercharger to my home Google Maps lists 76.3 miles.
However, I don't really think you can count on the online map numbers being accurate enough to be useful in this case.
The interesting bit in the data, which I didn't notice until after I posted this. Ellensburg <-> my house was a difference of exactly 0.3 miles and Ellensburg <-> Pendleton was exactly 0.6 miles. I find it hard to believe that it came out to that exact difference if there isn't some difference in how the cars are calculating distance traveled.
All that said 3-4 tenths of a percent difference doesn't seem like it's a big deal. So I'm not overly concerned about it. Probably well within the expected error difference. Could just be a matter of the difference in age of tires.
(snip)
We made no attempt to try and sync battery state of charge because of the differences in charging speeds.
(snip)
More food for thought, from a quick visit to Tirerack, shows OE Eagle tires at 755 revs per mi, vs. the MXM4s at 751. I'd expect the cars to have fixed revolutions per mile settings, however this difference is opposite to what is observed. The Goodyear shod S85 should over-state, relative to the MXM4 85D by .5%, if I'm looking at it right.
Thanks for the real world trial!
breser,
Minor thought... It looks like you both left from your house. Did the S85 also leave from your house cold soaked or did ThortsMD drive to your place, top off then continue on? Just thinking that maybe the early on results were higher for your S85D because it still had to warm up, where the S85 didn't.
I drove from my house in Seattle to Breser's...about 25 miles. I did not top off at his house. It was in the mid 50's and my garage was warmer, so I was not cold soaked.
