I with the speed dial went a bit higher. Plenty of roads around here with higher speed limits and I'd like to see how steep the range drop is going from say 70 to 80 mph.
Yeah, and colder please. 32degF ? Useless. Show me range at 0degF please...
That's true, but keep in mind that not all the loss is from drag. At 65 mph the drag is about 60% of the total resistance so the range difference due to air density is about 10%.
Using some guesses and cinergi's heater number my very rough estimate is that at 65 mph going from 70F to -4F there's about a 30 wh/mi difference due to air density and only slightly less due to the heater. Don't take these numbers too seriously though.
I'm surprised that the smaller batteries seem significantly more efficient than the 85 kwh battery. They lose less range with increased speed and the 40 kwh battery does 4 miles/kwh at 55 whereas the 85 only does 3.5. The 85 kwh battery car has about 88% of the efficiency of the 40 kwh.
I wonder if that is battery efficiency or increased weight of the car.
Another possibility is that the smaller battery cars have taller gearing in their transmissions, essentially trading off some acceleration for better energy efficiency. What would the range of the 85 kWh car be with the transmission of the 40 kWh version?
You're right - it's listed on the specs pages. Maybe the smaller capacity cells in the 60 and 40 kWh cars have lower internal resistance? Then they could run to lower charge levels.
Exactly, with constant speed acceleration losses and drag shouldn't be any different for the different batteries. Rolling resistance goes up with weight, but that's not a big component of total losses.
Rolling resistance also increases with mass, the tire rubber is deformed more with higher vehicle weight. Rolling resistance - Wikipedia, the free encyclopediaInertia goes up with mass, not rolling resistance (which is a property of the tires). Of course, there's also more kinetic energy stored once you get up to speed.
As eledille pointed out, rolling resistance goes up roughly linearly with weight and while inertia and kinetic energy do go up with mass, the mileage comparisons are at constant speed so there is no change in either that would require power.Inertia goes up with mass, not rolling resistance (which is a property of the tires). Of course, there's also more kinetic energy stored once you get up to speed.
http://en.wikipedia.org/wiki/Rolling_resistanceRolling resistance also increases with mass, the tire rubber is deformed more with higher vehicle weight. Rolling resistance - Wikipedia, the free encyclopedia
At 0 °C, my new Hakkapeliitta R tires roll so easily that the difference to summer tires is so small that I can't really say there's any difference at all, but at -15 °C speed dropped off noticeably.
[/URL]Not if tire size is also increased commensurate with the load. The contact pressure is almost exactly equal to the air pressure so the tire tread compound is NOT deformed more. Actually, it may be deformed less if the tire has a larger overall diameter.
Wikipedia is a very poor source for authoritative information. It's the reference of last resort because anyone can put any kind of drivel in it.
