Sometimes I wonder about our sanity. We pay 100K or more for a car, and then have to suffer through the cold or sweat bullets when range approaches zero.:biggrin:
The fact that I knew of several places to charge along the way and was ready to do so if needed eliminated any range anxiety.
No matter what kind of car you drive, you will be anxious if you come close to running out of fuel with no fueling station nearby. The way to avoid that is...to not do that! Always plan on getting more fuel well before you run out. For an EV, you can do some complicated calculations like the ones I have HERE, but the easier way is to always leave 1/3 of your range as a buffer. Make sure you know of a charging stop within 2/3 of the miles that your car says you have. I always plan my charging stops no more than 177 miles apart, and I never have to slow down, turn down the heat, or worry about getting there. Never! Driving an electric car can really be worry-free if you just follow that one simple rule.
Hypermiling in the Winter...Brrr
Yesterday, I drove 228 miles with 2,000 feet elevation gain (12-14 equivalent miles, total 240 equivalent miles) in on a range charge of 255 miles in a P85, arriving with 13 miles left in the battery. The temperatures on the route ranged from 40˚ F. at the start to 12˚ F. on some passes, and probably averaged 26˚ F. or so.
The route was from the 70 Amp J1772 in Pagosa Springs at 7,000 feet to the Supercharger in Silverthorne at 9,000 feet. (169 N 7th St, Pagosa Springs, CO 81147 to Silverthorne, CO - Google Maps) I had hoped that the 70 Amp J1772 would be installed in Salida for this trip, but the electrician was delayed and I needed to get back to Boulder. :crying:
Range Consumers:
- Freezing Rain and Road Spray that Require the Defroster - Going over Poncha Pass, the temperatures dropped to 22˚ F., some freezing rain and/or road spray started icing up my windshield and obscuring my visibility, and forced me to go to full, high defrost, and turn off range mode to be able to see. In 10 miles, I lost about 4 miles of reserve range.
- Slush - Driving through slush is a real drag, literally. Going over Wolf Creek Pass there was a mixture of hard packed snow, wet roads, and slowly melting snow in between. I could feel the tires cutting through the slush. To minimize losses, I tried to keep the wheels on the hard pack or on the wet pavement. Even so, with the 45 mph speed limit over Wolf Creek, I am usually able to build several rated miles in the crossing. Yesterday, I lost a mile or two. Luckily, the lowest temps were about 27˚ F and I was able to rinse the spray and slush off of the windshield with the deicer, windshield fluid.
- Cold - Cold uses extra energy to keep the cabin and battery warm. I started just as a range charge ended, so the battery started warm. Also, during the range charge I turned on the climate control and set the temperature to 77˚ F. for about 40 minutes to store as much warmth in the cabin as possible. For the first 30 minutes of the trip, I was able to drive with the climate control off, and was comfortable with this stored heat. As the outside temps went down, I had to turn the heat on and off at its minimum 64˚ F. with the "blue, cool" defroster mode on to keep the moisture from my breath from fogging up the inside of the windshield. I wish the temp could be set to lower than 64˚ F. After the first half hour, I drove with my fleece, wool cap, and gloves on. The seat heaters are a good way to stay warm without using a lot of energy. I found that putting my fingers between my leg and the warm seat was a great way to warm cold fingers.
- Loss of Aerodynamics from Ice - See the picture below. I did not realize that I had this much ice in the wheel wells until I went over 60 mph on the descent off of Fremont Pass, the car (5.6) went into "Low" suspension mode, and the road pushed the suspension into compression. Boy, was that I surprise when the studded Hakas started grinding into the ice. I had no idea what was causing the horrible sound until I stopped and walked around the car. BTW, when over 50 mph, the car will not let you force it back to "standard" height with 5.6.
Range Extenders
- Slow Down - I knew this trip was going to be a challenge. Depending on how I felt I was doing, I set my maximum speed somewhere between 50 and 55 mph. Only after crossing the last pass, Fremont, when I knew I had Silverthorne made, did I take the speed up to 65 and 70. It was great to drive at speed with the heater blasting. I would have arrived with closer to 20 in the battery without this extravagance.
- Tail Winds - The effect of tail winds can be huge. After the big loss of range over Poncha Pass, and with the temperatures dropping, I was about to pull into an RV park with 14-50's, but as the park came into sight, it has a U.S. Flag out front that showed I had a great tail wind my direction. The forecasts were for this wind to keep going over Fremont Pass, so I decided to push on. Between Leadville and Fremont Pass, it was pure joy to watch the cold snow, ground blizzard push snow down the road in front of me.
- Hypermiling - Gentle, energy efficient driving helps. Accelerate and decelerate gently; when possible plan ahead and feather the accelerator pedal to decelerate without using regen. Use cruise control whenever safe. Gently enter and leave cruise control by matching the accelerator pedal position to the cruise speed when turning cruise control on and off.
- High Altitude - Density altitude is not quite as high when the air is cold, but its still better than sea level. For the aerodynamic losses, I probably have at least a 15-20% advantage on this drive that averages 8,000 feet over doing the same drive at sea level.
I did not know if I would be able to finish this drive on one charge, and there were at least two points where I was ready to stop and add a little to the battery. The fact that I knew of several places to charge along the way and was ready to do so if needed eliminated and range anxiety.
Plan ahead and bundle up. Hopefully, the next time I do this drive, the 70 Amp J1772 will be in Salida and I can drive a little faster and stay warmer. :smile:
Great report Cottonwood - thanks.
A friend of mine takes delivery of his P85 on Wednesday, the first day of the really cold weather. I will see him Thursday evening anyway, but I think I'll call him before he gets his car and let him know what to expect in the way of consumption, lest he think his new car is somehow broken.
Slowing down by itself solved my range anxiety.
I hope he does not have the super performance 21's, or if he does, is getting it delivered with some winter 19's. Those performance tires go to a glass like state at cold temps and can be very slippery, even on dry pavement...
Ugh, thanks for the warning. I'm taking delivery of my Model S tomorrow and it arrives on the 21" wheels. Once registered at DMV I'm taking it to the tire shop to swap to 19" wheels and winter tires, but I will have to drive ca 6km in the city traffic and it's been snowing and it's a bit icy with temperatures around -2..+5C the past day or so. I'll probably keep 2-3x bigger distance than standard on this 6km trip.
I don't recommend you do this. Did 5km last year with the summer tires on a snowy road and I almost crashed the car two times. Performance summer tires are very dangerous in these conditions.
If it were me, I'd get the tires swapped before taking delivery. Just not worth the risk. I don't think 2-3x will do it if there is anything other than dry pavement.
