What about with 80% battery level on a fairly flat highway with the AC on with minimal to no wind.Lots of other factors will play in too. Level ground, uphill, downhill? Ambient temp? Headwind or tailwind? Charged to 100%? Could swing the range higher or lower by quite a bit in some cases.
Thanks. Long-Range it is.from my personal experience, with my P85, im probably losing somewhere between 15-20% because i am driving 75-80mph and running AC all the time.
The reason I'm asking is that I plan on doing frequent drives from San Francisco to Los Angeles to see my parents. It seems like with the SR I will need to stop at least 2 times to charge and with the LR I can probably get away with only stopping once.75 mph on the highway in lower temps with some grade changes could easily take the battery down to 150 miles, possibly less. That's also the range on a brand new battery. Battery will lose at least 1% of max capacity per year through normal use.
I think that short range is a great option for someone who needs a short range commuter and errand runner.
Do you have a philosophical objection to SC use ?I think that short range is a great option for someone who needs a short range commuter and errand runner.
You start out with ~ 90 more miles of range. If a SC adds 3.5- 4.0 miles a minute to a SR car, you save ~ 25 minutes travel time each way to gain those miles, and then some more time additional SC stop since the LR charges up to ~ 40% faster.The reason I'm asking is that I plan on doing frequent drives from San Francisco to Los Angeles to see my parents. It seems like with the SR I will need to stop 3 times to charge and with the LR I can probably get away with only stopping once.
?... what range should I expect from the short-range battery?
An answer to your OP
So long as your 310 mile battery choice does not delay my receipt of a 220 mile battery choice, both Elon and I applaud your decision.I think the time savings is worth it for me to get the LR. There's nothing wrong with stopping at the SC, but I like having the option not to.
This depends on person driving style.
My Model S says EPA 259 miles but I get nearly 300 miles.
My Model X says EPA 295 miles but I average out 335 miles per 98.4 kwh cycles..
So if EPA calculation is 220 miles. I can expect about 250 miles at least for base.
This makes the Model 3 a really good car.
