No2DinosaurFuel
You are correct that the 85 will no longer have the full 265 mile range and 255 is indeed likely, but you cannot then say the mileage difference will be closer between the cars because the 70 will also degrade. The most rapid degradation is said to happen in the first year, so presumably after a year or two you will be close to the published differences in range between the two cars.
Right, but you will still have more miles on the S85 compared to the 70D. Once everything settles, you will have a closer than 25 miles difference in max mileage between the 2 cars. Keep in mind the S85 will always have more cycles on it will always be older. If you assume that the 70D will cycle harder, then MAYBE you can argue they will be closer to the 25 miles, but 70KW and 85KW is close enough to make it negligible. If anything, the S85 batteries will go out first if you extrapolate to greater than 10+ years. Still, it may not be 10 miles difference, but probably only a 15 miles difference. But I doubt a 25 miles difference.
