Reapply Calif HOV sticker installed with ppf?
Discussion in 'Model 3: Interior & Exterior' started by bickie, Jan 24, 2021.
  1. bickie
    bickie Member
    Southern Calif
    I applied my California HOV stickers to a piece of ppf for easy removal later when it expired. Didn’t think about what if I needed to remove and REapply it after an accident. Anyway, the accident happened and I need to remove then reapply the stickers. How do I do that?
    Thanks!
  2. jjrandorin
    jjrandorin Moderator, Model 3, Tesla Energy Forums
    Riverside Co. CA
    wouldnt it be easier to request a duplicate sticker since yours was "damaged in the accident"?
  3. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
    You should be able to use a little heat from a hairdryer to soften the PPF and grab a corner and slowly pull it off. Then just you a little water from a spray bottle to reapply it to the newly fixed bumper.
  4. bickie
    bickie Member
    Southern Calif
    Cool thanks. Didn’t know reapplying would be that simple haha. Thought it was 1-time use adhesive. Thank you.
  5. bickie
    bickie Member
    Southern Calif
    Good planB. The stickers aren’t damaged, so trying to salvage what I can. Thanks.
  6. bickie
    bickie Member
    Southern Calif
    Gave it a shot with a heat gun. Bottom line ended up not working for me. I was impatient and started pulling before heated enough. The sticker separated from the ppf leaving some ‘void’ marks on the ppf. Not sure if I can reapply the sticker to new piece of ppf. Big plus, both removed cleanly off the bumper. So, planB it is!
  7. jjrandorin
    Riverside Co. CA
    You may have to pay a nominal fee for it, but I seem to remember a choice on the forum you submit to get the first one to request a replacement.
  8. bickie
    bickie Member
    Southern Calif
    Will check. Thanks for the info.
  9. dskillz
    dskillz Member
    Los Angeles
  10. Pkmmte
    Pkmmte Le meow
    Los Angeles, California
    This happened to me before. It was too difficult to re-apply so I ended up requesting a new one for $22. Only took 4 months to arrive. :/
  11. bickie
    bickie Member
    Southern Calif
    4months. Ouch. In process of getting replacement too. So lame we have to go thru all this.
  12. bickie
    bickie Member
    Southern Calif
  13. MODEL+
    MODEL+ Vendor
    Portland, OR
    Can someone inform an ignorant non-californian the significance of this sticker? I've seen this eye sore on beautifully modified cars and I'm always confused... the incentive better be good enough.
  14. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    I never saw the value of putting the stickers on, so we don't use them, but I'm retired. Most HOV lanes are open to two or more people in a car, and except for high volume traffic during "rush" hours allow full usage. As one who drives when I want, I just go when the HOV lanes are open to anyone and never have a problem. If I started work in San Francisco at 8AM, I'd need to use the freeway and drive in the packed traffic, or buy a sticker for my car and drive in the near empty HOV lane. After 10AM, the sticker is not required. Same holds true for PM traffic. Many companies allow for flexible hours and people arrange work schedules to coincide with traffic.
    It's far less of an eye-sore than a front plate.
  15. stopcrazypp
    stopcrazypp Well-Known Member
    It's a HOV/carpool sticker which allows you to use HOV/carpool lanes during rush hour even with one person in the car. If you commute a lot, it can save a lot of time.
    Also you get discounts at bridges. For example, crossing the Bay Bridge costs only $3 during carpool hours instead of $6.
    San Francisco-Oakland Bay Bridge - FasTrak
