Rear 22" OEM rim on front of X ??
rekoh
360
16
Minnesota
Questions for the group - I have an opportunity to buy 4 rear 22" Tesla rims. .. don't ask me why, but the guy has only rear rims for sale. That being said, I am considering putting the larger (10" i believe) rims all the way around the car. I have *heard* that if you put the larger tires (285) on the larger rims, they will rub in the front of the vehicle. The seller says I can put the smaller (265 vs 285) tires on the front rims and that will work. The rims are about 3/4 inch different in size.
Any insights, thoughts, experience, or expertise would be appreciated..
Here are my concerns:
1) The bead of the smaller tire (265) on a larger (10") rim on the front could cause blowout, leak,whatever..
2) Larger rims on the front will compromise brake system or components up front
3) I am not worried about range
Thanks TMC !
rekoh
360
16
Minnesota
*Update*
TireRack says the tire (265) will definitely fit the rim, but will make the car handle differently since the sidewall (stretchy-ness?) will be different from front to rear, and the front being tighter? will potentially lead to oversteer situations.. they don't recommend doing it.
Reactions: McManX
rekoh
360
16
Minnesota
another thought....
Could you put 265 tires on the 22" rims all around to keep the sidewall consistent, and allow for proper tire rotation?
siucity
Button Pusher
Feb 18, 2015
407
208
SF North Bay, CA
another thought....
Even if you could, I've never gone with narrower (even though 265 isn't necessarily narrow) tires. It'll probably affect your handling, but as to how much, I don't know.
Pandamoanium
655
254
Colorado
If there wouldn't be any damage, I'd imagine oversteer could potentially be nice when cruising. Steering wheel selection could play or balance this too.
