What I meant is my to get my ratchet on the bolt and have enough leverage to turn the bolt the brake disc would come in the way (it’s a fairly long ratchet) . Going to take a stab at this again Sunday and see if I can gain better access to the bolt, or use a shorter ratchet.What do you mean the rotor was in the way? The brake rotor? I'm not sure I understand how that could be in the way of the inner mounting bolt. When I did mine, it was just a ratchet on one end, and a box wrench on the other.
FYI, before you install the replacement links, make sure you set them to the same length as the stock links...that way your car drives straight until you have time to get an alignment.
And since you're using fixed lowering links, you'll want to install the aftermarket camber arms with the adjustment side facing OUT (towards wheel). That's the only way to make sure that your camber adjustment doesn't move the ride height sensor mounting point, thus raising the car in the back. Makes adjusting the camber a little more annoying (wheel needs to come off), but that won't be a problem for a performance alignment shop and it's still less annoying than having Tesla reset your ride height every time you get an alignment.
IIRC, each half turn of the adjustment arm moves your camber value by 0.1 degrees in either direction
Thanks for the tips and removal guide!
