Mysterylectric
Bump steer was a concern of mine when installing these (We have god awful roads here in NY, and you will hit bumps in every situation). I tried to compensate for the change in upper arm geometry, by extending the toe arm a little more than stock (See my alignment sheet above). The characteristics of the car through turns and over bumps hasn't changed drastically. The car does turn more with the front (if that makes any sense) and it seems to "pivot" more around the centerline, but there hasn't been any noticeable change to the dynamics of the steering over uneven roads. The major difference I noticed is under HARD braking. I believe the issue lies with the fact I never had the rear suspension calibrated for the change in ride height, so when the car nose dives, it unloads the rear wheels completely, and they go pretty far positive on the camber, resulting in the tires riding on the outside shoulders. The X-Ice tires I had on the car also played a role, as the have exaggerated shoulders, and a very soft compound compared to the all seasons I run the rest of the year. A proper set of performance tires with closed shoulders would likely do wonders on mitigating these issues, but I'm not overly concerned. The car handles a very light rear end very well, and from a high speed stop, it only seems to initially unsettle, and then catch itself right away.I realize this is a difficult question so if you have not tested It, please say that. What change to the bump steer of the rear wheels does this give, if any? Raising or lowering the inboard link would change how parallel the pivot arms are and there fore the camber change as the wheel moves up and down. Camber will not affect bump steer like toe in, but it will affect it some.
