Vendor Rear Adjustable Camber Bushings for Model S/X Group Buy
Discussion in 'Model S: Driving Dynamics' started by EVTuning, Mar 14, 2018.
  1. WASD
    WASD Member
    Culver City
    I have a set of n2itive camber AND toe arms (you'll need both to get proper adjustment when lowering) for sale in the classifieds, new in box. PM me if interested.
  2. STALIZE
    STALIZE New Member
    Home
    After buying a ‘17 P100D from Tesla this summer on fresh 21” Michelins I drove for a little less than 6k miles before noticing that the innermost 1” of my front tires were showing metal this past weekend. The rest of the tire was like new. I replaced the fronts with Michelin All Seasons yesterday and took it in for an alignment today. I came here because of a search to see what people are doing on stock cars to try to reduce rear negative camber. (The fronts were shot on mine because my car had way too much toe out). I had my car aligned today on Low, but before pulling the alignment heads off, I raised the car to Standard to see the change in specs. (L/R) Front camber went from -1.0/-.6 to -.6/-.4. Rear went from -2.0/-2.2 to -2.0/-1.5
  3. STALIZE
    STALIZE New Member
    Home
    Why didn’t you install them?
  4. dark cloud
    dark cloud Active Member
    BC
    One rear reduced camber by 0.7 degrees, and the other one was unchanged? That makes no sense, unless one of the struts is not working??
  5. WASD
    WASD Member
    Culver City
    I sold my car shortly after I got them. I also sold the arms earlier this week. If I got another S and lowered it, I would get them again.
  6. Aggmeister2010
    TX
    I bought the EV Tuning ones today. They should get here in a couple weeks. When they do, I’ll post more info.
    my plan is to remove the old control arms, set the adjustable arms to the same length, drive immediately to an alignment shop, and get my camber adjusted. Then, boom! done.
  7. The Duke
    The Duke Member
    What alignment specs will you use?
  8. Aggmeister2010
    TX
    Probably just a modification of the factory specs. Keep everything factory, except get the rear camber as neutral as I can while keeping the wheels in the arches, I'm hoping that equates to about -1.5 degrees each side.
  9. Pluturi
    Pluturi Member
    Upstate NY
    FWIW, my tech suggested that if your goal is to minimize tire wear while running in Low the majority of the time, have it aligned at Standard height per the procedure and aim for -1.0 as it will get a little worse when you move to Low.
  10. The Duke
    The Duke Member
    IMHO, align with car on low and try for 0.9 degrees camber and 0.1 toe. Add a little toe if the rear wanders too much, but mine tracks well. BTW, running 285/30 on the rear, YMMV. Alignment is slightly off with high suspension settings, but that is on dirt roads so I don't care.
  11. Aggmeister2010
    TX
    that's the goal. I'm also running 285/30/21 on the rear, on some Vossens that are like 0.5mm from the strut tower.....so the more neutral camber will do me good.
    Can you share pictures of your stance with 0.9 camber?
  12. Doanster1
    Doanster1 Member
    Oregon
    Really +0.9 camber (positive)? Or did you write 0.9 assuming performance cars always have some degree of negative camber out back? Honest question/just making sure as I’m debating on getting a set of camber arms as well. Thx.
  13. Aggmeister2010
    TX
    He definitely meant -0.9.
  14. Doanster1
    Doanster1 Member
    Oregon
    That’s what I thought, but just making sure as I said. Thanks.
  15. The Duke
    The Duke Member
    Yes, dropped the minus sign.
    Thanks Aggmeister2010
  16. Aggmeister2010
    TX
    My order is shipping today, hopefully I can get them installed next week and get to aligning!
  17. Aggmeister2010
    TX
    Folks,
    My EV Tuning Camber Arms arrived today. These look sharp, and I'm excited to get them installed. I'm going to take my factory ones out, and line up the bolt holes so the alignment is unaffected until I have time to go get it re-aligned.
    Does anyone have any alignment specs that they recommend? Not sure how a flatter rear camber would impact the factory toe specs...
    FYI, the average user ONLY needs the camber arms. The factory toe arms have plenty of adjustability in them, and they're pretty labor intensive to replace anyway. I believe you'd have to drop the subframe.
  18. Pluturi
    Pluturi Member
    Upstate NY
    I had my EV Tuning arms installed by Electrified Garage. These are the specs and results of where they put mine.
  19. Aggmeister2010
    TX
    How's it drive? Any pulling or wander? Does it feel stable?
  20. Pluturi
    Pluturi Member
    Upstate NY
    I drove cross country RT and it felt perfect.
    I think the only thing to be cautious of is the suspension height when aligning as not too many shops are familiar with that ability in MS. When I suggested aligning in Low as that's where I intended to run, Electrified Garage was adamant that it should be aligned in Standard after getting it on the alignment rack and cycling it up to High and then back to Standard.
