Hello. Same problem. But I didn't do anything with the chassis. One day it is received, the front is sitting, the back is high. What restart did you do? Sorry for the English, google translator.
Thank You.
To reset your MCU’s, press and hold the steering wheel scroll wheel and the button directly above it, on both sides. Four buttons, four fingers, and hold until both screens go dark.
When the mcu’s fully restart, go to service & safety menu in touchscreen settings, then “power off”, agree to the process, and let the car sit a solid five minutes. They say 2 minutes, but my older model s takes 4-5 minutes to make its final noises and clicks. During that time period avoid touching anything, opening doors, etc.
If confusing, this
MCU Reset Article should fill in anything I missed and may translate better since it’s published.
After this reset process is complete, press the brake to turn on car.
I’ve heard of the S getting stuck in Jack Mode on only the rear, which confuses me a little but im not an air suspension expert. Try toggling the Jack Mode feature after the reset, then pressing the suspension height options to see how the car reacts.
One last thing I tried last year was driving the car beyond the 30kph and 50kph threshold for it to “automatically” lower. I also set automatic “low” to 30kph, but it never initiated in back. The front always acted correctly.
My situation was definitely due to hardware, but I did a lot of expensive diagnosis visits only to realize eventually that the camber arm product would never work, and the seller simply didn’t know what they were doing.
Hope you can find a solution.
