Rear bumper alignment issue
Discussion in 'Model S' started by brycerocky, Aug 6, 2018.
  1. brycerocky
    brycerocky Member
    Santa Clara
    I've had my S for 8 months and it seems that the back bumper panel alignment has gotten worse over time. The driver side seems flush but the passenger side seems to be popping out now. Can't figure out what's happened since there's no damage at all to the bumper. Not sure if they had to remove the bumper during a past service visit. Has anyone else had this issue? Could this just be some unsnapped clips and something the service center can address?
  2. TM Parts
    TM Parts Teslamotive
    Sacramento
    It looks like it needs to be adjusted at the edge. You can see the tip of the bumper is far too inside of the car. You can do it yourself if you want. It's a T25 bit that you can loosen a bit and push the bumper back where it belongs and tighten the screw.
  3. David.85D
    David.85D Active Member
    There is a row of snap clips that holds that edge of the bumper in place. Looks like they popped out or one or more broke. There are fasteners along the edge of the wheel well.
    Ask the service center first, they are very used to it and might be able to fix it in a jiffy.
    If that doesn’t work, I can give you a step by step guide to remove the whole bumper cover to see what is going on under there...
  4. OmahaG8
    OmahaG8 Member
    Omaha
    Just got my rear bumper repainted after someone hit me in a parking lot and I am now experiencing this issue. Repair place, Tesla certified, isn’t being very helpful. I’d just assume fix it myself.
    Do you have a guide handy? I’ve taken off bumper covers before but would like to know exactly where to pull for the 3. Thanks!
  5. David.85D
    I’ve only done this on an S. No idea about the 3. Probably better to post the question in the 3 section of TMC (this is the S section).
  6. OmahaG8
    OmahaG8 Member
    Omaha
    Ah, thank you - I just found in a google search and wasn’t paying close enough attention.
  7. BPSoCal
    BPSoCal Member
    Mission Viejo
    This is funny, on my S, the driver's side bumper looks like your picture, but the passenger side is perfectly flush.
