It doesn't matter- just either full toe in or toe out and same on both sides. Full toe out might make other adjustments slightly easier.Really helpful...the extreme position of the cam bolt...I assume tighten it all the way clockwise position?
N2itive has reccomendations here:Is the rest of settings good to minimize inner tire wear?
Do I need to get more closer to zero camber?
First, spin both of them all the way in so it is as short as you can make it.Is there any tips on setting up the adjustable toe rod end?
Do you set the smaller rod length the same as the larger rod to start?...somehow my was max out with a few turns.
To adjust...just loosen the 2 end nuts...and turn the big middle nuts?...which way is extend ...toward the body or the wheel hub?
Gearcruncher I appreciate your detailed Info. I’m currentl in the process of changing my stock, fixed rear camber. After 8 m’s How has the Hardrace rear camber arm heldup? Are you happy with the Hardrace camber? So, far I have found only 3 options - Hardrace, N2itive and Un plug Perf. I see EVT is no longer around, but I also heard it did not hold up well. I don’t know how accurate this is, but I read that the Unplug unit has the same design as the EVT. The N2itive unit looks solid, but like you I would like to save some money and spend it on some other improvement. I’m hoping to hear that the Hardrace is doing its job and holding up. Thanks for your feedback. RRPosting a review of the Hardrace Q0601 rear camber arms for the S/X cars.
These things are well made, and inexpensive (if you can find them). Aluminum main structure, with a curve very much like OEM. Appears to be CNC'd aluminum, shot peened, and then anodized. Reasonable adjustment method, and solid shielded pillowball/spherical bearings at the ends. Had no issues getting these aligned, although I do my own alignments, and don't align from below the car, so I can't tell how easy the adjuster would be to access. You can save a lot of time by making the hole ends 290mm apart, which will get you right around 0.4 degrees camber. The threads are slop free and didn't change alignment when tightening the lock nuts. Given the basically stock curve of the arm, I didn't find any issues with interference with anything even across a full swing of the suspension. When they are at stock length, the ride sensor hole is in exactly the same spot as stock.
Took about 10 minutes per side to install. The pillowballs are nice as you can tighten everything down while drooped, unlike rubber bushings. Have a couple hundred miles on them with no noises or issues.
These are pretty much unobtanium in the USA. I bought mine from the Europe seller, who had reasonable shipping to the USA. They seem to be on Ebay pretty commonly. I paid about $260 shipped to USA.
View attachment 762267 View attachment 762268 View attachment 762269
Jrad446- hello. I’m in the process of replacing my stock camber arms. It looks like there’s 2 options, Hardrace or N2itive. How are your Hardrace camber arms doing? Are they holding up, and doing to the job to eliminate the wearing out of the rear inner tire? ThanksThanks a lot gearcruncher! This helped me out a bunch! Was able to grab a pair of hard races out of Europe for $250 and a cheap camber gauge. You were spot on with the 290mm starting adjustment and the toe arm had just enough adjustment to get the tire back out right. Next stop Tesla for a finer alignment
Thanks for the update. How are your rear wheels wearing, especially the troublesome inner tire wear? Thanks again for all your info and insight. One other question. I know you put on the Hardrace camber arm and had no trouble. Do you do your on wheel alignments, or have an independent shop do it? I watched several DIY wheel alignments, and wasn’t sure if you did your own. Thanks again. BTW, I’m running 20’ streamline wheels off a Model X, with 255/40/20 square tires. I got that input from another member off a wheel post. He had road racing exp, and felt this was the best set up. Lots of trad on the road and can rotate the tires. I like mine, I think it’s a good option between 19 & 21s. Plus even # wheels have a lot more tire options. Also, based on what I’ve read about the car going into the low body mode and the extra stress on the rear camber/wheels. I turned off my low mode and keep it in standard. There’s only a 1/4” height difference from what I can tell. I have a P85D with 150K miles. No issues except for tire wear. Thanks RRCurious about your thoughts. And I’ve spoken with the SC and asked them why don’t they offer a 20” for the S. Obviously, they do not know, but said you won’t be able to align the 20s. I said the alignment has nothing to do with wheel#The camber arms have held up fine as far as I know. Just got back from a 3K mile road trip. I've had no issues, but I've also not done any kind of detailed inspection as I've had no reason to do so. I did adjust them about 5 months ago and they were fine and re-adjusted easily.
I have noticed no difference since I installed them.Hey there, what is the ride quality with these bushings and how are they holding up? Really concerned ride harshness will increase.
Essentially you focus too much on getting camber to your desired setting then find out you don't have the ability to set toe to spec because it could potentially be beyond the max toe adjustment. Not an issue if you have camber and toe links but if you want a specific amount of camber without toe links you (or your now pissed off alignment shop) could spend a lot of time balancing setting camber then having to undo your work to dial more negative camber until you have appropriate toe adjustments available to be within spec.@krsgio what happened? Can you elaborate?
Wow, are you sure? I believe you, bvut here's what I read about pillow ball mounts, which are essentially metal bushings replacing a much softer rubber bushing. I'd love to use them as I can buy the camber and toe links for les than just the n2itive camber linksI have noticed no difference since I installed them.
I drive race cars. I know what solid mounts are. You're replacing 2 of maybe 14 bushings in the back and none in front. I'm sure technically the NVH is higher, but I'm just sharing I didn't notice it. I'm sure you would if you replaced all 40 of them on the car.
