I will mention that the factory spec is actually toe-in (positive is toe-in, negative is toe-out). A factory alignment calls for about 1mm of toe-in front and about 3mm of toe-in, in the rear.
In addition, when the suspension compresses the tires toe-in even further. So, the issue is that under compression you can easily end up with a significant amount of toe-in which is going to wear the tires. I believe this is one reason that people have issues with tire wear.
That all being said, if anything, you want some toe-out in the rear. But, again, for a street alignment zero has been pretty good for me!
P.S. When did you get a Plaid!? How are you liking it?
