Rear doors open strangely
Hello, I typically open the front doors by pressing in on one side of the lever which lowers the window a litle and pops the door out just far enough that I can put my fingers inside the window and pull it the rest of the way.
I tried this on the back doors and got my fingers tore up. It seems that the window lowers and the door pops out just like the front but then the window goes up and it closes before cycling back to open. Is that normal?
BluestarE3
4,088
5,216
Norcal
If you use a digit of your hand to unlatch the door, why not use the other digits of the same hand to grab the now presented door handle instead of moving your hand up to the cracked open window to pull the door open?
CMoZ
256
316
BC
Wow you’re going to mess up the alignment of the windows if you don’t outright break something doing that. There’s door handles for a reason, also the window lowers to reduce the possibility of stress or torque on the windows when opening or closing, you’re basically undoing that
Minimize using the glass to open/close your doors. They're not designed for opening and closing your doors.
It's actually a big down side of frameless doors...I personally prefer framed doors.
The behavior seems somewhat odd...perhaps try it on another car or at a show room.
Amazing how many replies without answering my original question. Does no one know if this happens on their model 3 or not?
So a double cycle? Goes down then up then down again quickly while you are opening? Not normal. If the window drops then goes back up there is an issue or you are re-latching it where it thinks the door is closing and as such, will raise the glass.
smatthew
1,538
2,591
CA Bay Area
Yes. On the front door, I press on the handle, and the door pops open enough that I can then grab the shoulder of the door. On the rear doors, they don't pop open as much, and I have to use the handle as designed.
Reactions: Acousticmood
Mrcarcrazy
In need of a shrinking gun to zap a plaid with.
May 22, 2019
966
1,010
South Padre Island, Tx
It’s your cars way of saying “don’t do that dummy”.
In all seriousness that’s a terrible way to open the door. The glass is pretty much the worst part to grab ahold of. The reason none of us know is because we find it more entertaining to give you a hard time than to walk all the way to our garages and watch the windows move. (Or that could just be me).
Reactions: XLR82XS
