Rear-facing jump seats removal
AndreyATC
541
152
Cape Coral FL, USA
Could someone please tell me which tool to use to remove the 3rd-row seats?
I believe it's just couple of bolts on the bottom of the seats holding them secured to the car
Thank you
AndreyATC
541
152
Cape Coral FL, USA
Need help
SC is telling me something that does not add up in my head
i removed the seat by simply unscrewing two bolts pictured below
Used torx 45 and it worked well
it was a bit of an effort however
seats have been washed and I was ready to put back in
These two bolts are now simply going through the whole that seem like was threaded before
tech said I stripped the thread
i understand you could do that by overtightening something, but unscrewing ???
it is aluminum piece where the bolt screws into and it's not really thick to handle whole seat hanging just with thread
Is there a nut that was supposed to be on the other side securing the bolt?
Anyone ever removed/reinstalled the seats??
GRADIEGO
21
2
SoCal
You need the "barrel nut" that attaches underneath. They may have fallen down when you removed the bolt. You can probably fish it out and use again. Your SC will have them too.
Reactions: davidc18
Chris TX
1,531
186
Dallas, TX
That's odd. I've removed my 3rd row before, for a 1000+ mile trip and the nuts stayed in place for re-installation. It does look like your nuts have moved away from the holes, so It's probably going to take the Service Center to relocate them or install new ones. I wish they were more captive, for sure.
Reactions: davidc18
AndreyATC
541
152
Cape Coral FL, USA
Thank you for your help guys
Yesterday I came across very old thread which showed that barrel nut
I got the part number and ordered it this morning
I only was able to find one of them
Used paperclip the fish it out
BARREL NUT, M10 2006869-00-A $3.60
Lesson learned
If you need to take the seats out you have to somehow secure those nuts
maybe use magnets or some sort of paper clip to hold them in place
Reactions: davidc18
jaguar36
1,990
1,413
NJ
Can you get to the backside to put the new nuts on? I wanted to take out the seats to clean them before but I was worried about reinstalling them as well. Did you find a torque spec on the bolts?
AndreyATC
541
152
Cape Coral FL, USA
I'll have to find out about the torque
Though, it seems that the bolt regardless of position inside the nut is tough to rotate
Kind of like lock nut...
So even if it's not extremely torqued, it won't fall out
I also have good feeling on how tight it supposed to be, based on getting it out effort
skitown
869
2,255
Central Idaho, U.S.A, Earth
@AndreyATC curious if/how you were able to get the new nuts into position (per @jaguar36's query).
AndreyATC
541
152
Cape Coral FL, USA
You have to snake it out.
It's slides side-to-side in the channel and will never fall.
I was able to fish both of them with no issues
You need to get inside the threaded hole and go along the trunk surface to the side
buttershrimp
Click my signature to Go Mad Max Mode
Jun 17, 2017
2,705
6,198
ATX
Does anyone know if you can just use the bolt to hold the barrel nut in place until the seats are ready to reinstall? I want to remove the rear facing seats for a long road trip and I don't want to lose the nut... I thought about trying to get someone to weld something so I can easily detach and reattach the seats without losing the nut...
ultima
83
76
Netherlands, Rotterdam
I had the same problem... removed the seats (Torx45), installed the original bolts but wanted to swap them out with M10 hex nuts. (way more grip to remove and reinstall them). When getting the bolts from the store I forgot to reinstall the orignal bolts with the result that the nuts were gone...
But it is an easy fix.
Get a strong small magnet! Move the insulation next to the holes aside and you will see two big square holes... use the magnet to find the nuts and slide them to one of the square holes... re-position the nuts behind the fixing holes and you are good to go...
