Rear facing seatbelt twisted
Discussion in 'Model S: Interior & Exterior' started by roopesh, Aug 2, 2017.
  1. roopesh
    roopesh Member
    San Diego, CA
  2. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    There have been several cases of this. The strange fix seems to be, pull it all the way out, twist it 180 degrees to make it the 'right' way, let it wind all the way in, and it should fix itself. I didn't believe it either, but others with the issue say it does work (and it's the Tesla fix also). I surmise there's a twist inside and this reverses it?
    Edit: Whoops, I didn't look close enough to see this was a jump seat... not sure that works exactly the same way!
  3. David.85D
    David.85D Member
    Maryland
    Are you sure it isn't the plastic chest buckle that got turned the funny way and not the belt? Those belts are all manual adjust and bolted down at the end.
  4. Jimmy 1
    Jimmy 1 Member
    Tallahassee, FL
    It is hard, but you have to fold over the strap and pull it through to correct it.
