Can you see your 'high level' brake light from inside the vehicle? We had roof glass recently replaced and had not noticed this before. Did a brake pedal reboot and whilst waiting for it to finish, noticed that I could see our brake light in our rear view mirror. View via rear view mirror showing brake light bleed. Its actually much more noticeable than in the photo.
I'm getting the feeling that this is not normal then? I might have a closer look to see if anything obvious ie a cowling that needs adjusting
IIRC, someone here had a similar problem after, I think, having window tints installed, and it turned out to be damage to a foam light shield that is intended to ensure that the light unit is sealed tight to the glass.
i thought this was normal - i had my tints done on the day of delivery and have always seen the brake lights from inside. Perhaps they damaged this "foam". Would a visit to the SC remedy this, or no cause for concern?
Yes this appears on mine too - after some night driving last week I noticed in the rear view mirror. I haven't added it to my big snags list for today's SC visit but I might mention it. Not a biggie for me compared to the other issues with my car
This post seems to describe the same problem, and refers to the foam strip : Third brake light problem
I can see this very slightly, but to be honest, I actually find it quite helpful so I know when regenerative braking is illuminating the brake light.
