New assembly, LEDs are soldered to a PCB.I've noticed two LEDs in my rear passenger trunk mounted light have burned out. Is it possible to replace the burn outs or do I need to order an entire new piece?
(my assumption based on other designs, no first hand knowledge)
If your car is 2016 or later:
https://epc.teslamotors.com/#/systemGroups/60261
LIFTGATE TAIL LAMP ASSEMBLY - BACKUP - SAE - RIGHT
6005924-00-E
E-bay?Darn.
If you can get the soldered array out, you can desolder the defective LEDs and solder in new ones. The problem is going to be matching the brightness.
Looking at your picture, the lights look symmetrical. Are you sure there are bad LEDs? Even if there are, I am not sure it is noticable, not to me anyway.
If they bother you enough to replace the light I’d be interested in attempting the repair, as more of a challenge than anything else. I suspect the light is a heat sealed unit, if so it’ll be nearly impossible to get to the soldered board without destroying the light. If the light is held together with screws, it should be fixable.
If there is a easy way to open them up please let me know. This guy has been hitching a ride for an awful long time.
My drivers DRL is fading bad. Passanger side just started to fade. March 2017 car. First problem.I have a similar issue happening on my passenger Daytime Running Light LED. I'm under warranty though so TesMobile is coming out today to fix. In this case it's an full light assembly replacement.
