Was underneath my MS this morning and noticed this equally on both sides on the bottom of the control arms:
It's at about a 45 degree angle pointing down. There's literally nothing I can from suspension fully compressed to full extended that would get remotely close to this. The closest thing is the rim of the wheel itself and the only thing that lines up with that angle but there's no sign of rubbing on the inside of the rim. It's at least an inch away from it.
It's even on both sides. I'm completely stumped. But I remember someone posted something similar a while back. Not sure if it was the same part.
The only reason I checked is there was another post recently about a rear lower control arm failing so I got paranoid and decided to check. Glad I did.
The other parts damaged are the wishbone links which are cheap. The control arms are going to be expensive.
