Rear passenger door opens unexpectedly
Discussion in 'Model S: Interior & Exterior' started by sxnahm, Aug 6, 2016.
  1. sxnahm
    sxnahm Member
    San Francisco, CA
    I recently had my car given its annual service, during which they updated the software to 2.28.60. Shortly after the service I started noticing that the left rear door would pop open at different times. Most often it will do it when the car is unlocked and the handles present. However, one time it did it when an autopark completed (hmm, I guess the handles present then too).
    I have a service appointment for Tuesday to look into it, but in case it's related to the software updated I wanted to mention it here. It is intermittent -- doesn't always happen. I was able to catch it on video, though:
  2. JPP
    JPP Active Member
    SF Bay Area, CA
    ...bet you have a failing/out of adjustment exterior door handle. When you go into Park, and the handles extend, if the handle moves just a bit too far out (or is out of adjustment) it will hit the microswitch and pop open the door. Should not happen when driving. Unlikely related to software. Service center will adjust/replace the handle as appropriate. Been there...done that.
  3. NikeWings
    NikeWings Active Member
    You have courage to park so close to other cars with your beautiful blue S.
  4. sxnahm
    sxnahm Member
    San Francisco, CA
    Just had the service visit today, and they told me that the latch mechanism failed and they had to replace the handle assembly.
    So not a software issue.
    FYI, the car is 13 months old -- a little early for this sort of failure, I think.
  5. chillaban
    chillaban Active Member
    Bay Area
    If it's any reassurance: I've had 3 other non-Tesla luxury cars before my Model S, never kept a car more than 2 years, and can tell you an hour's worth of stories about how they've all been in the shop for various issues during that short course of ownership.
    Unfortunately I think it's just a fact of life that stuff breaks on a complex car, no matter who makes it. And one failure doesn't necessarily imply another failure.
  6. JPP
    JPP Active Member
    SF Bay Area, CA
    The early builds (2013) had more problems with the extending-retracting handles. Revised handles much better. You can still have a 1-off failure. I would not stay awake at night worrying about it.
