Rear Trunk height override?
Discussion in 'Model X: Interior & Exterior' started by ND100, Apr 21, 2016.
  1. ND100
    ND100 Member
    NSW
    According to the Model X manual the rear trunk's opening height can be set. Does the car allow you to override this?
    For example, the way Mercedes handle this is that you hit a button (remote or on the car). The trunk opens to the preset height. If you then press the button again it'll open to the full height. This is handy if you regularly park in a low area, but on occasion want to open it to the full height.
    Does the Model X behave in a similar way?
  2. Dazureus
    Dazureus Member
    Michigan
    Tagging along because I hope someone has an answer to this. I was wondering if this feature existed, but tap and holding the trunk FOB button already opens the charge port so that's out.
  3. sukhi
    sukhi Member
    Palo Alto
    #3 sukhi, Apr 21, 2016
    Here is how it works:
    Standing behind the car open the rear hatch.
    When the rear hatch is in the process of opening and reaches the desired height, press and hold the hatch open/close button (the one on the hatch) until you hear a beep
    This position will now be saved as the default open height position. If you need to set it to a higher position just manually push up the hatch beyond the set position and reset the height as above.
  4. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    There's your answer. Use your hand and push it up - not the absolute ideal, but not a problem at all.
  5. sukhi
    sukhi Member
    Palo Alto
    Not ideal at all as I am afraid of pushing against the motorized panels but unfortunately I could not find a better way. I think it would be better if Tesla provided a software interface to set the height and made it a driver specific setting.
  6. ohmman
    North Bay, CA
    FWIW, I've been doing it on my Model S for 2 years and have had no issues. But my anecdote is merely that.
  7. sukhi
    sukhi Member
    Palo Alto
    Good to know.
    By the way did you notice that it is NOT possible to stop the hatch manually when it is moving up? it has to be done using the button on the hatch.
  8. ohmman
    North Bay, CA
    Maybe something to add to your next SC visit punch list. I just went out to the garage and tested. Mine stops if I hold it. It takes a bit more resistance than I'd like, though, so I'm adding it to my list too. It should be pretty sensitive, considering you don't want it to smash the spoiler on the way up if an obstruction is hit.
  9. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    Huh? You can do that each time. Or just do what Sukhi said the 3rd post. At least that's how it is with the S. I will test it on my X when I get it tomorrow.
  10. sukhi
    sukhi Member
    Palo Alto
    @jomo25
    You are right. Pressing and holding the button on the hatch at the desired height sets the height. Unfortunately once you set it, there is no way to move the hatch beyond that height except manually pushing the hatch up to new desired height.
    @ohmman
    Thanks. I was a bit scared to apply too much resistance but it definitely needs fixing as that's the only quick way to stop it from smashing into any low obstructions.
  11. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    It would be nice if they programmed it so a double click made it go all the way up. I will send a note to Tesla to suggest that.
  12. ND100
    ND100 Member
    NSW
    Thanks everyone. It's a shame they didn't go the way of Mercedes which doesn't involve pushing against the motor system. One button to close, and tapping the 'open' button a second time opens to full height.
    This means I can have a small opening by default (safe for inside/tight spaces), but when outside tap it a second time for a full opening for larger items.
  13. jomo25
    Scottsdale, AZ
    Ok now I understand what was being asked.
  14. aesculus
    Northern California
    How do you close it then? That's why I suggested the double tap to open fully, still allowing the single tap (used most often), to close it.
  15. ND100
    ND100 Member
    NSW
    FWIW, there are two buttons on their (recent) cars. One closes the trunk or sets the max height, and the other opens it (use it once to open to the preset height, tap it again to open to full). I don't think their fobs/remotes let you open to max height.
  16. Dazureus
    Dazureus Member
    Michigan
    Two buttons? I'm aware of one just above the license plate to open it, and the round one at the underside of the trunk lid to close it/set the height. Is there another one somewhere? If I double hit the opening one above the license, will it open to full? Gonna try this out during lunch.
  17. sukhi
    sukhi Member
    Palo Alto
    I think the above description was for how Benz does it.
  18. TeslaTrojan
    TeslaTrojan New Member
    Los Angeles, CA
    I was having the same issue lately, since max opening of the trunk would have the spoiler hit the garage door in our garage. I reset the opening height to a lower height to avoid damaging the spoiler, but now I keep hitting my head on the trunk when putting stuff in the car. It would be nice it they could make this GPS tagged like the smart air suspension to remember locations that need a lower opening height, but allow full opening when outdoors etc. I also don't see why they couldn't tie it in to the sensors that detect ceiling height for the FWDs.
  19. ohmman
    North Bay, CA
    Yeah, these are the two most reasonable choices I think. They could even be combined, if desired. That is, open to the max height detected by the roof sensor unless you're in some GPS coordinate range. And while we're at it, crowdsource that.
    Instead, Tesla will solve it by implementing "trunk eject" which will be tied in with summon. Press a button, all of your belongings are ejected out of the back, the hatch closes, and it goes into your garage. Problem "solved".
  20. aesculus
    Northern California
    Or maybe put that spoiler away whenever the car is in park. I have mine set too for the height with the spoiler up and always hit my head. Today I went out and the spoiler was down and I was able to open the trunk a lot higher.
