doctorwho
I've just got the same problem with the rear hatch, at the same time I've also lost TACC and Autopilot
Yes, obviously nanny did the programming. It's a shame for me that it happened as I was packing the car for a 700km drive with no driver assistance featuresTACC and autopilot disable when this happens. That’s often the biggest inconvenience, besides having to get into your boot/trunk via the rear seats
Heh - Mine occurred after loading shopping from supermarket at supercharger, though was only for another 200miles - you don’t realise how much you value something like autopilot until you don’t have itYes, obviously nanny did the programming. It's a shame for me that it happened as I was packing the car for a 700km drive with no driver assistance features
Well, thankfully I stumbled upon a way to silence the annoying trunk open beep, which as I said goes on for a full minute once you put the car into Drive or Reverse. For reference in case anyone else is unlucky and gets this problem, here’s how:The only solution to the annoying beep is to turn up the music volume.
Ok, issue resolved:
FYI - Step 7 is a bear... you gotta be a contortionist and pressed up against the glass of the lift gate to pop that thing.
- Remove the parcel shelf supports
- Remove headliner side bolsters around the trunk opening
- Remove the bridge plastic trim at the top of the lift gate
- Remove the side vertical plastic trim from each side of the lift gate
- Pop loose the top of the rear plastic trim from the lift gate
( it won't fully disengage due to the handle inserts at the bottom of the lift gate )- Reach down with a small flat screwdriver and disengage the power lead to the Clinch motor
- Using the small flat screwdriver, rotate the clinch motor emergency release mechanism
( Rotary pulley looking thing on the back side of the clinch motor )- Viola! lift gate released!
- Open lift gate
- Fully remove remaining trim panel
- Remove Clinch motor ( 3 torx screws )
- Install new Clinch Motor
- Test lift gate functionality
- Re-install all trim
( Replace any trim which has broken bits )
Hope this process helps someone else to at least get the lift gate open. Releasing the clinch motor may free up whatever caused it to bind and allow it to work normally until you can get a service appt or a ranger to visit. Or, maybe this will help you guide a ranger on what needs to be done.
This thread helped me as I was able to advise the ranger to bring a clinch motor (which he normally didn't have with him). He said he's only seen lift gate issues 3 times in the past X years he's worked at Tesla (including time working at the factory), so the failure rate on these is low. Further, this was the first time he's had to use this process to open a stuck lift gate.
LK
Hi. I found this thread and just registered in this forum. I’m German, so sorry for my bad English (only school English).
I just came back from skiing holidays, arrived at home and tada ... the trunk won’t open
Of course the emergency unlock didn’t work.
So because I’m out of warranty and 3,5 hours away from the next SeC, I would try my best, to get it fixed.
Just a few questions to your guide to fix it:
1. How do I remove the parts you have discribed? Is there any trick to remove the parts from No 1-5? Or can I pull the headliner, and the covers simply out?
2. To find what I’m searching for, how does the Cinch Motor itself and how does the its emergency release mechanism looke like?
3. You are writing about disengaging the powerlead to the cinch Motor .... how does this powerlead look like?
Are there pictures to my questions No 1-3 to finde in this forum?
Thanks in advance
Flo
(Who just wanted a lazy Sunday, but now has to try get the fu,/€7@ Trunk done )
Thanks for the great tip locking the car, although the trunk is opened a bit
