Has anyone noticed that the rear vents seem louder since the 8.0 upgrade?
I usually have both the front and rear vents set to 6 as the sound level dramatically increases once you hit 7 or higher.
After upgrading to 8.0 last night, I noticed pretty easily that the vents in the back seemed awfully loud. At first, I checked to see if the fan speed was at 7 or higher accidentally. It was at 4, then I figured some of the louvers in the back must be shut and its forcing more air out other vents, making them louder.
All vents were wide open and interestingly enough it's not the second row vents that are any louder but both 3rd row vents that are the culprit.
This Is even at a fan speed of 4 while 7 has always been the threshold for audibility.
Well, that's my vent (pun intended) with 8.0 if indeed its 8.0s fault.
Has 8.0 messed with fan speed?
Anyone else notice that the rear vents are louder than they previously were at the same fan speeds?
