Rear view camera - Kenwood CMOS 310 on JVC KD-NX5000
Discussion in 'Roadster 2008-2012' started by asgard, Oct 23, 2013.
Tags:
  1. asgard
    asgard Member
    Dietsch Werks (http://www.dietschwerks.com/), the same guys who installed the Nitron race shocks on my Roadster
    also installed the Kenwood CMOS 310 camera on my JVC. The screen on the JVCs is not great but the camera still works well.
    Dietsch Werks built a custom Y bracket that screws onto the license plate screws and hangs behind the plate.
    The camera has 5 adjustable views that you can rotate through using a pushbutton. Dietsch Werks mounted that
    behind the starter keyhole.
    The switch cycles though Wide-angle, standard, Bottom, Top/Bottom Split, Dual Corners.
    I am pleased with the quality of the work and the camera itself is incredibly useful. The way Dietsch set it up, it turns on
    when you back up, or you can turn it on even when the car is in drive. The Dual-Corner view is great for blind-spot viewing.
    The attached image is flipped upside down for some odd reason...
  2. shrink
    shrink Supporting Member
    Phoenix, AZ
    I just had a back up camera added to the JVC as well. I used the JVC-KVCM20. However, my car is still at the shop so I can't speak to the installation or how well it works. Will post an update once I get it back.
  3. shrink
    Phoenix, AZ
    Finally got mine back. It's solid. No complaints:
