I specifically checked the rear view mirror in an owner's car recently. I did not find it to be a problem.I find the inside rear view mirror to be unacceptably small. From any seating position, one can see to the limit of what is visible through the rear window. But when I move my head just slightly, I can't see the entire rear window. Does anyone else find this disconcerting?
LoL missing auto dimming function?Cheap, goes over the original, and you could remove it anytime.
https://www.amazon.com/Broadway-BW8...id=1535133310&sr=8-1&keywords=broadway+mirror
Just received a 10" flat Broadway mirror. Does the job, but just a bit too wide. Positioned it a bit to the left of center, where it clears the passenger's sun visor entirely, allowing my wife to check her eye makeup in the mirror. This position interferes with the driver's visor if flipped all the way forward, but not if one just lowers the visor to the vertical position. I'll be keeping it, but 9" would have been perfect!
Mounting is very slick: paired spring loaded clips on the top; fixed clips on the bottom.
While the original mirror is a bit small, it doesn't bother me, and I really like how it looks especially with the small bezels. This thing... not so much.View attachment 330119
Mirror is shifted to left, so it clears the right visor entirely, but prevents the left visor from being rotated through its entire arc. I don't think this will be an issue, as the left visor is used only when the sun is low and the visor is rotated only down to the vertical position.
