Rear wheel vs all wheel drive range
Discussion in 'Model 3' started by thebeezknez, Aug 23, 2018.
  1. thebeezknez
    thebeezknez Member
    Las vegas
    Does anyone have a real data the shows the distance rwd vs. awd can get? I’ve heard some say that the rwd has more range is that true?
  2. usofrob
    usofrob Member
    Michigan, United States
    This is a pretty good comparison, but your actual mileage will vary significantly on local conditions. But I think this allows you to compare the different versions reasonably well:
    Tesla Model S/X/3 range at 65/70/75/80 mph
  3. Daniel in SD
    Daniel in SD Active Member
    San Diego
    One quibble is that I would expect the range of RWD and AWD to get closer at higher speeds as aerodynamic loss becomes a higher percentage of the energy use.
