Rebuilding after my accident
Discussion in 'Model S: Driving Dynamics' started by GasDoc, Jun 12, 2013.
  1. GasDoc
    GasDoc Member
    SF Bay Area
    #1 GasDoc, Jun 12, 2013
    Finally some good news! Parts for my Car are supposed to arrive on June 19. The accident was May 25. Can you tell that I cleaned my car the afternoon before it was hit?
    With some luck, I'll be able to take my car to Teslive--It'll be tight though. After the bodywork is done, the car has to go to the Menlo Park Service Center to have airbags and seatbelts replaced. i'm going to have them fix my squeaky Pano roof and replace one of the door handles while it's there.
  2. FalconNinetyD
    FalconNinetyD Active Member
    GasDoc, did I miss you posting what the official estimate $ to repair is?
  3. Al Sherman
    Al Sherman It's about THIS car.
    Batesville, IN
    I can sure tell it was cleaned. Here's hoping it'll look great again soon!
  4. NEWDL
    NEWDL R#350 R#1323 Sig23(traded) 8136, RWD LR 3, P3D
    NE OHIO
    What is the concern for battery at this point? It is still isolated I assume to vamp load is minimal if at all but was/were there any concern expressed or suggestions/expectations voiced?
  5. AMPd
    AMPd Active Member
    Northern California
    Glad you'll be getting your car back soon!
  6. Galve2000
    Galve2000 Member
    NYC
    Are they replacing the battery completely?
  7. EdA
    EdA Model S P-2540
    Massachusetts
    Ditto!
  8. GasDoc
    GasDoc Member
    SF Bay Area
    Here's what Tesla had to say about the battery:
    ...Given the normal loss of range due to electronics, and the charge state of your battery pack at the time of incident, I am very confident that no long-term degradation effects will be observed regarding your standard range outside the standard curve.
    Also, if the state of charge becomes exceedingly low, we have safeguards in place to minimize the chances of permanent loss of range outside normal use. For example, the vehicle will hibernate to preserve the residual charge in the individual cells. It is not until the car loses this residual value that there is any danger of long-term effects outside the standard degradation curve. The vehicle can also alert us proactively when the state of charge becomes alarmingly low, so we can enact measure to prevent long-term effects.
    Usually, the vehicle must be without charge for a period of months before these effects will begin to occur, so rest assured, in this instance, you are safe.
  9. brianman
    brianman Burrito Founder
    Thanks for sharing, GasDoc.
    That response addresses the "charge decay while unplugged" concerns. Have they said anything about the more mundane aspects of your battery pack? Like whether it was crushed or otherwise deformed in the collision?
  10. GasDoc
    GasDoc Member
    SF Bay Area
    The car hasn't gone in the bench yet but it appears that all the damage was done to "bolt on" components forward of the battery.
  11. brianman
    Awesome for you, and for the brand. :)
  12. ZestyChicken
    ZestyChicken Member
    Dallas TX
    Wow I thought they would total the car but I guess since it hit the front where you basically have crumple zones. Doesn't look like it even hit the front wheel. That's great!
  13. brianman
    On the one hand, I think it's a great research opportunity if there's any physical trauma at all to the pack.
    On the other hand, it's a great feather in their cap to show that it was "just a flesh wound" and get it back on the road with most of the original vehicle.
  14. GasDoc
    GasDoc Member
    SF Bay Area
    I don't think that anything even crumpled. The blow bounced off the reinforcing beam behind the nosecone.
  15. ZestyChicken
    ZestyChicken Member
    Dallas TX
    Silicon Valley engineering >>>>>>>>>>> German engineering. (-:
  16. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    Your Model S will forever be known as the Model S that (literally) ate an M5.
  17. brianman
    Haha. It's okay to laugh since the other driver wasn't injured right? :)
  18. bollar
    bollar Disgruntled Member
    Southlake, TX
    So, he basically keyed his car by running into you...
  19. CapitalistOppressor
    CapitalistOppressor Active Member
    There have been times where I would have enjoyed being able to key a car quite that thoroughly...
  20. TI Sailor
    TI Sailor Supporting Member
    Treasure Island, FL
    It seems Tesla has missed the opportunity to test out its new battery swap system. :biggrin:
