Found this thread after having "Retrofit HCU Wake-Up Wire" done today. I was wondering what this is supposed to fix.
plus they checked tires pressure and tread depth (did not ask for it).
Also, they performed "Update Vehicle Firmware to Correct Boombox Functionality"!? Did not ask for this too.
I made another appointment to fix Autopliot. As always, the communications are not existent. Ellon has been talking about improving service. Can't wait but my expectations are very low.To fix this: "In rare circumstances, braking and stability control related alerts may appear on the instrument cluster and touchscreen during the vehicle power-on process. Such faults can typically be corrected and the affected functionality restored with a vehicle power cycle."
Most states require that they perform that any time they work on a vehicle.
That was a "safety" recall that NHTSA required.
Yeah, it seems to be related to a ground wire for the brake controller. Seems like they shouldn't have a problem doing it.Since this is related to brakes, I wonder if they will do this on my car - have the MPP rotors. I have service scheduled for a creaking driver side seat and they added this to the service list
I’m getting this ground wire thing done right now, and interestingly they added it after having to fix my seat. Driver’s seat was creaking/popping, and they ended up replacing entire seat. But then seat heaters did not work, and they ended up having to repush firmware to fix seat heaters. Weird. Anyway, boombox and this wake up wire was added. I’m not sure why boombox would not have been already fixed since i have 44.25.5 Already.Since this is related to brakes, I wonder if they will do this on my car - have the MPP rotors. I have service scheduled for a creaking driver side seat and they added this to the service list
I’m getting it done too, but also a front radar sensor replacement due to water intrusion , I’ll try and ask what it’s forI’m getting this ground wire thing done right now, and interestingly they added it after having to fix my seat. Driver’s seat was creaking/popping, and they ended up replacing entire seat. But then seat heaters did not work, and they ended up having to repush firmware to fix seat heaters. Weird. Anyway, boombox and this wake up wire was added. I’m not sure why boombox would not have been already fixed since i have 44.25.5 Already.
I think forward collision warning still uses front
