The other issue I have is the orientation of the radiator. If it's the condenser of an air conditioning system, its orientation doesn't really matter. Any water that accumulates on it will run off. But if it can function as an evaporator/chiller, it should be oriented such that any water that blows in through the louver does not tend to collect on it (perhaps it should be on top of the cavity behind the louver, and there should be drain holes on the bottom of the cavity, for example). Otherwise you'll just have to defrost it more frequently than otherwise necessary especially if it is 3°C and raining and the temperature of the radiator below freezing. And of course, they should have heaters at the bottom of that cavity to make sure that ice doesn't block the drain hole.
