Out of curiosity when was your car built and which model is it?I installed the update last night and it didn't fix it for me. Car is programmed for scheduled departure and was plugged in overnight. tried rebooting it again this morning, but still no heat since 6 Jan. service appointment is set for 21 Jan.
This is an "undocumented change". Those notes are not from Tesla.I just got an update, and it seems to address the heat pump issue:
2021.44.30.6 Official Tesla Release Notes - Software Updates
Tesla software update 2021.44.30.6 includes Charging Options, Improved Heating, Track Mode, Light Show, Customizable App Launcher, Simplified Controls, Blind Spot Camera, Edit Waypoints, Boombox Megaphone, TikTok, Sonic the Hedgehog, The Battle of Polytopia - Multiplayer Support, Sudoku...www.notateslaapp.com
"This release includes changes to how the climate system works in vehicles with a heat pump. If you have experienced a lack of heat in your vehicle, this update may solve the issue by allowing the heat pump to work at lower temperatures."
Off to Collingwood to ski, and it's going to be -25C.
Sept 2021 Model 3 SR+Out of curiosity when was your car built and which model is it?
The firmware fix is to address keeping the heatpump running if the louvers stick open in cold weather. If you're still having an issue then you could be experiencing a hardware fault. Do you have a ticket open? The techs will remotely diagnose each car that is experiencing issues and provide individual guidance. In my case they decided within a few hours of experiencing my heat loss that the hardware was not likely the issue. What have the techs told you?I installed 2021.44.30.6 and the exact same issue persists. It's only -4ºC out. Very disappointing.
That seems to be in the range when they were replacing manifolds and heatpumps. Have the techs remotely diagnosed your vehicle?Sept 2021 Model 3 SR+
I assume you must have some kind of hardware problem. What is the error code (or is there one)?I installed 2021.44.30.6 and the exact same issue persists. It's only -4ºC out. Very disappointing.
Same as previously.. VCFRONT_a447I assume you must have some kind of hardware problem. What is the error code (or is there one)?
Yes I have a service visit scheduled (two provinces over) for the end of the month. They troubleshooted remotely and have proactively ordered a new compressor and supermanifold, not being entirely sure these are required but just in case. This was before the software update came in. I've let them know I've applied it with no resolution... patiently awaiting further updates.The firmware fix is to address keeping the heatpump running if the louvers stick open in cold weather. If you're still having an issue then you could be experiencing a hardware fault. Do you have a ticket open? The techs will remotely diagnose each car that is experiencing issues and provide individual guidance. In my case they decided within a few hours of experiencing my heat loss that the hardware was not likely the issue. What have the techs told you?
don't think so. just the generic park in a heated garage, use auto temp, pre condition car, etc. when i said that didn't work, they changed my mobile appt from 12 Jan at my house (i mentioned i didn't have a warm place to work out of, just outdoors) to 21 Jan at the garage they work out of on the other side of the city. Tesla doesn't have an official service centre here, just a garage bay i believe.That seems to be in the range when they were replacing manifolds and heatpumps. Have the techs remotely diagnosed your vehicle?
