Wanted to provide some of my observations during a recent scheduled grid outage to replace some old power poles.
I have a 8.43kW array connected to Sunny Boy 6.0 (6kW max output) and a single Powerwall 2 / Gateway 1 (FW 22.1.1 and iOS app v4.6.1) in a partial home backup setup. Given this my system is certainly maxing out inverter and what PW is capable of managing and I had never tested the grid outage capability in extreme situations so was interested to see what would happen with this scheduled outage during during the day on what would be a good solar production day.
Power was cut about 9.30am so battery had started to charge and was @ ~70%. Battery continued to charge to ~80% during outage which seemed to coincide with ~3.4kW being sent to the battery (I think this is max allowed in "normal" operation). For next 4 hours house was using ~0.5kWh and inverter would cycle on for brief periods charging at rates in excess of 5kW (see first 2 pictures) and maintained a 80% charge. At about 2.45pm (battery still charged to about 80%) the inverter turned on permanently and seemed to charge Powerwall at rate of 5.2kW (see 3rd picture showing battery behaviour during the day). Power was restored about 3.30pm and about 5 min later normal operation reasumed.
During the day I was expecting the cycling of the solar as excess production was going to be > 5kW but the Powerwall did seem to accept the input for a few minutes and did not immediately shut down and certainly later in the day (@ ~2.45pm) it did allow 5.2kW continuously so I wonder if it was simply optimizing what is needed to do to balance need v pushing throughput to the extreme but at the same time making sure battery @ 100% at end of day... I also noticed from my Ting monitor (a great fire safety monitoring device I got from a partnership they have with my insurer, StateFarm) that the voltage was being allowed to vary significantly (see 4th picture); I suspect this is how Gateway / Powerwall manges the power throughput without exceeding the 30 amp maximum.
