Recharging on the go
JRP3
Hyperactive Member
Aug 20, 2007
19,432
42,585
Central New York
As I traveled the interstates this holiday I considered the practicality of using some sort of "third rail" induction charging for sections of the highway. I'm sure this has been discussed somewhere before but I was thinking of maybe 2-4 mile strips of high energy charging capacity. At 60mph you'd get a 2-4 minute charging boost, if you needed more you'd slow down to 30mph for twice as much. With an Altairnano type 10 min recharge battery you could almost get a complete charge from a 30mph pass over a 4 mile strip. Of course this would take a massive amount of capacity, so more likely than a full charge would be lower capacity partial charge strips.
What say ye all?
JRP3
Hyperactive Member
Aug 20, 2007
19,432
42,585
Central New York
If practical to implement it certainly eliminates the "range" issue of EV's and allows "fueling" on the go, something ICE's cant offer.
insndrvr
15
2
Even if you had some sort of third rail, every car would have to have a standard mechanism to reach the power, and would the cars drive themselves while touching the rail? I wouldn't trust the average driver to follow a yellow line, let alone a high voltage power strip.
Then there is the problem of the slow car, if one person decides they need to go 30mph, then everyone has to go that slow.
I could see something at rest areas for fast charging while you are using the bathroom. At 60mph driving 200 miles would take almost 3.5 hours. Most people are going to need to stop for something in the time frame.
JRP3
Hyperactive Member
Aug 20, 2007
19,432
42,585
Central New York
With induction charging there wouldn't have to be actual contact. Yes you'd need a standard mechanism for each car, just like we have standard air valves for tires and standard fuel fills for gas.
Good point. You'd need separate lanes, still feasible.
Sure, I expect we'll have that. Just thinking about what might be done on the fly.
JRP3
Hyperactive Member
Aug 20, 2007
19,432
42,585
Central New York
A recent thread about magnets that linked back to this one got me thinking about another possible version of this concept. Might it be more efficient to use energy to propel the vehicle like a rail gun or maglev instead of recharging batteries? Might be inefficient to carry around enough magnets to make it work and I don't know the efficiencies of the propulsion system, plus the cost of installation. The idea would be you pull into the "maglev" lane and are pulled along for a while till the next exit or something.
vfx
14,790
40
CA CA
More patents
http://appft1.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PG01&p=1&u=/netahtml/PTO/srchnum.html&r=1&f=G&l=50&s1="20070131505".PGNR.&OS=DN/20070131505&RS=DN/20070131505
A novel system for easily aligning a ground mounted power supplying electromagnetic inductor to a vehicle mounted power absorbing electromagnetic inductor is presented. The power supply inductor is preferably mounted within a parking block or a speed bump. The power absorbing inductor is mounted in a vehicle, preferably between the front tire and the front bumper. When the vehicle's front tires touch the parking block or the speed bump, the two electromagnetic inductors are aligned sufficiently to transfer power efficiently.
