Recirculate Switch Not Working?
Discussion in 'Roadster 2008-2012' started by Pantera Dude, Mar 31, 2013.
Tags:
  1. Pantera Dude
    Pantera Dude Member
    Long Beach, California
    The recirculate/fresh air switch doesn't seem to do much in my car. I always have fresh air coming thru my vents. Are all the roadsters like this, and is there any fix? The reason for all these questions at the same time is because I have my dash off and I'm trying to kill five or six birds at once. :biggrin:
  2. djp
    djp Model 3 Performance
    Toronto, Canada
    Mine is the same - I don't think there's anything you can do to prevent the Roadster cabin from being drafty.
  3. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    Yes at least in my car even with recirculation on I still get some air coming in. It is less with recirculation on but I still have some air coming in.
  4. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Here's the trick for cutting the air flow to minimum - useful for winter hypermileing. Turn on recirculate. Set air to vents. Close all the vents!
    This actually works pretty well. The only thing to remember is whenever you come into a town and have to stop, flip it to defog and turn the heat on low. Otherwise you'll fog over. Once you're back underway again flip it back to the vents.
  5. vfx
    vfx Well-Known Member
    CA CA
    I keep them closed all the time. Only open when needed.
  6. Pantera Dude
    Pantera Dude Member
    Thanks guys. I think I read something on a Lotus site that talked about completely blocking the fresh air intake. I guess that would solve the leaking problem but I'm not sure I would want to give up the fresh air?
  7. Thirstyturtle
    Thirstyturtle Member
    Wilmington, NC
    Mine is also very drafty even with the recirculation on, in fact I'd say it's the same with the recirc on or off. It made for a very chilly night drive a few weeks ago when i was trying to hypermile on the interstate for about 200 miles. I ended up turning the recirc on, putting it on the top vents, and closing those vents. It's less overall airflow but you definitely feel the draft up top then.
    Boy do I wish I could "close" all the inward air flow, I always end up having to run the heat if it's even chilly outside because the outside air just BLOWS in :mad:
  8. Pantera Dude
    Pantera Dude Member
    During my dash removal project, I noticed that the vents close/seal like none I have ever seen. It looks like they should block virtually 100% of the flow. Each vent has a blade behind the flaps you see on the front of the vents. It looks like a great design! Unfortunately the main fresh/recirculate flap doesn't work quite as well.
  9. hcsharp
    hcsharp Active Member
    Vermont
    According to the manual, on recirc it still gets 20% of the air from outside and 80% from inside as I recall. It does this by design.
  10. Saftwerk
    Saftwerk Member
    Bavaria
    The knob has a nose on his rear side.
    That nose was broken on my very orange, so turning the knob had no longer any effect.
    It was fixed by Tesla Munic for free.
